SOURCE: Front loader door will not open after a washing cycle is finished
call the repair man it is a comp. issue
SOURCE: j845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
SOURCE: door not locking
Doot lock hook may not be engaging or door lock is faulty- wiggle the door around while pushing on it, check the door hook , replace the electric latch
SOURCE: sumsung J845 front load washing machine cannot open the door
What you need is a Samsung service repair manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thank you for the manual, it helps me take off the top cover, but I am still in the same problem. But thank you all the same"
SOURCE: I have a front louder
The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
