Question about Cameras
I bought a vivitar x035 and I took around 50 pictures on it they are a special occasion when I go through my pictures through the camera they are there but when I connect my camera to my lap top they won't appear anyway I could get these photos as they mean alot
Posted by Stephanie Graham on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Posted on Aug 04, 2013
5 Related Answers
Anonymous
  • 85 Answers
SOURCE: My PC Wont recognize my camera! 5 Stars!?
1. Connect USB cable to an available
USB port on your pc. Turn on your ViviCam 7410. Select [PC] using the c / d buttons and press the SET button. From the Windows desktop, double click on “My Computer”. Look for a new “removable disk” icon. „This “removable disk” is actually the memory (or memory card) in your ViviCam7410.. Double click on the removable disk and locate the DCIM folder.
2 select "Start" and control panel. click cameras & scanners see there for your cameras if it is there then ok.
Posted on Mar 17, 2008
Ty Price
  • 11967 Answers
SOURCE: Uploading New Photos
Buy an inexpensive card reader to download your pictures to a folder you create on your desktop. That way, you can select which ones to download to the folder.
Posted on Oct 20, 2009
Anonymous
  • 73 Answers
SOURCE: Vivtar Freelance Camera...All pictures gone!
Most likely, yes. Try to use a USB card reader. Take the card off the camera, put it in the reader and connect it to the computer. If there is no sign of files, download PC Inspector File Recovery, install it and run it. You can get it from here: http://download.cnet.com/PC-Inspector-File-Recovery/3000-2248_4-10118663.html
Good luck in saving your pics.
Posted on Apr 12, 2010
Ty Price
  • 11967 Answers
SOURCE: My SONY Cypershot DSC-W55 lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 30, 2011
Ty Price
  • 11967 Answers
SOURCE: aI have a Panasonic Lumix
This could be a lens error...try some of these:
Posted on Jun 28, 2011
How do I know I'm using the SD card on my vivitar camera
Take a picture, then turn off the camera. Turn the camera back on and see if you can review the picture you just took. If you can then the picture is on the memory card.
Jun 15, 2012 | Vivitar ViviCam 8025 Digital Camera
Apr 12, 2010 | Vivitar ViviCam V15 Digital Camera
Can not clear memory of Vivitar 10x25 binocular camera
If you want to delete the pics just take out the batteries and the pictures are gone.
Dec 29, 2008 | Vivitar MagnaCam Binocular/ Digital Camera
Program can't find pictures
If you take batteries out before you download them you loose the pictures. Catch 22
May 28, 2008 | Vivitar MAGNACAM Binocular
Batteries for a 5340s camera
have discovered www. batterypowerplus.com They list all cameras with the appropriate batteries. from their list i got the information that np900 batteries fit not only my vivitar5340s camera but about 30 other cameras as well
Apr 06, 2008 | Vivitar ViviCam 5340s Digital Camera
10x25 camera binoculars
This is simple digi cam
XP and above needs no driver
remove any software and let Windows do the work
If images a poor send it back this is a poor product
Jan 05, 2008 | Vivitar MAGNACAM Binocular
Vivitar mini Camera
I just bought the Vivitar mini digital camera and everything installed really well but when i click on "My Camera" it say "cannot connect to camera". My camera is plugged in to the USB port properly and it shows PC on my camera but i cannot get the pictures please email me at [email protected] if you know how to help! THNX!
Nov 17, 2007 | Vivitar ViviCam 35 Digital Camera
Vivitar camera shows black mark and no picture when switched on
wait have you changed the batteries yet? If not make sure there CLEAN and unused.
Apr 23, 2007 | Vivitar ViviCam 5150s Digital Camera
Cameras Logo
157 people viewed this question
Top Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
