Right side door fan is defective disconnect defect one than clear error and start your device problem will be solve if problem persists change fan.
If fan is good you will change the DC controller.
you can solve this error by following these steps Options->Under the Hood->Change proxy settings->LAN
Settings -> Automatic Configuration -> Automatically detect
settings = ON
Close GC Restart
It should load the
page(s) as expected.
Resolved on WXP-SP3 not running GC.
Turn
OFF Windows Firewall. Last MS Update must have turned it ON.
found this solution, maybe it also helps to solve your error.
Try and change OCR language
he was scanning documents with danish language to PDF and OCR language set to English. Received the same error, changing OCR language to danish solved his problem.
If not
go to HP support webpage: http://www.hp.com/cgi-bin/hpsupport/index.pl
choose support and tr.. information option
enter your product name
and check if there is a fix published.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
