Candy AQUA1000T Front Load Logo
A
Anonymous Posted on Aug 04, 2013
Code e108 has come on the display - Candy AQUA1000T Front Load
Panasonic home theather does not read DVD and display a U703 code
Panasonic display motor Home Theater Systems Questions ...
www.fixya.com > Forum > Tags > display motor > Home Theater Systems
Panasonic home theater systems display motor related questions and answers. Ask your ... ...getting a DVD H02 code it wont play cd's or dvd it will display the code and say stop. Is this fixable or should ... ...display a U703 code. Does I need to ...
Panasonic euromax new codes Home Theater Systems ...
www.fixya.com > ... > euromax new codes > Home Theater Systems
My Panasonic home theather does not read DVD and display a U703 code. Does I need to bring the equipment to a repair center or is better to get a new one?
Panasonic Home Theater System System Dvd u703 ... - Fixya
Have a code error E108 and machine is not pumping out or spinning
Probably Can't spin when full of water and can't get rid of water because of pump blockage or pump failure.
Even a sock in pump?
Turn of electric
Slide a curtain spring rod into the outlet hose until it hits the pump.
Give it a few pushes and jerks to see if it frees up any junk.
Pull out the spring cable and test.
Hold hose down on floor to drain out.
Does it spin now?
How do you put in the code for a kenwood kdc-4022 head unit
1:-Select SOURCE Select ALL OFF
2:-Press MENU for 1 second, When "menu" is displayed "security"/"SECURITY" is displayed
3:-Press the [<<] or [>>] for one second. When "ENTER" is displayed "CODE" is displayed
4:-Select the digits to enter by pressing [<<] or [>>] button.
5:-Select the security code numbers by pressing [am] or [fm] button.
Repeat steps 4 & 5 to complete the code.
7:- Confirm the code by pressing [>>] for at least 3 seconds
When "RE-ENTER" is displayed "CODE" is displayed.
Go through steps 4,5,6,&7 again to re-enter the code and "APPROVED" should now be displayed? The security code activates?
Press the re-set button and remove from power source Turn ON go through steps 4,5,6,&7 to enter CODE and "APPROVED"" should be displayed.
Crikey need a beer now, Happy tunes, have a good drive.
Regards, Dave
What kind of fuse do i need for it
The unit uses two 300 watt halogen lamps so it draws around 5 amps for just the lights and a small amount for the motor. The E108 is a carbon copy of the Chauvet Double Derby that used the halogen bulbs. My Chauvet is marked as using a 7 amp fuse for 120 volt operation or a 5 amp when used on 230 volts.
PLEASE open the unit if the fuse blew as it is likely there is an internal problem if nothing more than a light bulb that shorted as it burned out. There are slip rings and the sockets that need to be inspected if the fuse did blow.
8helpful
2answers
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
1helpful
I have got a vreg corsa with a stereo that hasnt got a display.could u please tell how to put the code in because the numbers only go to 6 on the stereo and in the code there is a 9 and 7 please help the...
Find your Blaupunkt instructions on this free Code Entry website.
http://www.radio-code.co.uk/code-entry-help.php
The exact instructions will depend on the radio model.
If your display is NOT working and you have the CORRECT code then the usual method to enter the code "blind" is to ADD 1 to each digit.
So Code 1234   would be entered "blind" as 2345
A typical Blaupunkt with a separate display is the model CAR300
Below are the Code Entry Instructions for that model
(Don`t forget to ADD 1 if you are entering the code "blind".)
 INSTRUCTIONS TO ENTER A BLAUPUNKT CAR 300 (no display ) RADIO CODE
Switch the ignition key ON
Press and hold
AS button *  and the  ON button at the same time
Display Shows SAFE  then goes to 10 - - - - with a
"Beep" from the speaker
Press Preset Button "
1 "repeatedly until the 1st Digit of your Code is displayed
2" repeatedly until the 2nd Digit of your Code is displayed
3" repeatedly until the 3rd Digit of your code is displayed
4" repeatedly until the 4th Digit of your code is displayed
If the display  now shows the correct Code number then
Press  Button
AS  and hold to Enter and if successful  there should be a "Beep" from the speaker and the radio should switch on
I have the code put it in still not working dont no how to put it in
NOTE: IF YOU TRIED UNSUCCESSFULLY TO ENTER YOUR CODE YOU MAY BE PROHIBITED FROM ANOTHER ATTEMPT FOR UP TO 24 HOURS. See below--section C
A. Input Security Code:
  1. Enter Standby: Press the [SRC] button. Select the "ALL OFF" display.
  2. Enter Menu Mode: Press the [MENU] button for at least 1 second. When "MENU" is displayed, "Security"/"SECURITY" is displayed.
  3. Enter Security Code mode: Press the [|<<] or [>>|] button for at least 1 second. When "ENTER" is displayed, "CODE" is displayed.
  4. Select the digits to enter: Press Press the [|<<] or [>>|] button.
  5. Select the Security Code numbers: Press the [FM] or [AM] button.
  6. Repeat steps 4 and 5, and complete the Security Code.
  7. Confirm the Security Code: Press [>>|] button for at least 3 seconds. When "RE-ENTER" is displayed, "CODE" is displayed.
  8. Do the step 4 through 7 step operation, and reenter the security code. "Approved is displayed and the Security Function activates. However, if you enter a code different from your security code you have to start over from Step 4.
B. After Pressing the Reset button or when removed from power source.
  1. Turn the power ON.
  2. Do the step 4 through 7 operation, and reenter the security code. "APPROVED" is displayed.
C. If an incorrect code is input, "WAITING" is displayed and the input prohibited time shown below is generated. After the input prohibited times lapses, "CODE" is displayed, and input can be done.
1 Time = 0 minutes
2 Times = 5 minutes
3 Times = 1 hour
4 Times = 24 hours
Here's a link to the manual:
http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KDC-MV6521~6021~5021%20(EN).pdf
1helpful
2answers
Due to remove the car battery from my car the stereo akking me for code (password) I know what is it, but where is the enter key on the detacheble face
1 Enter Standby
Select the "STANDBY" display.
2 Enter Menu mode
When "MENU" is displayed, "SECURITY" is
displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
4 Select the digits to enter
Push the Control knob to [
4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
The Security Code function activat
Good Luck
2answers
Unlock ford car radio. have code.
can you give the number or name of the model
Top Candy Washing Machines Experts
Kolbrun...
Oliver Street
ADMIN Andrew
ADMIN Andrew
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
