I have a router wich i want to install but what im using is a usb cable and now i dont know how to switch from usb to ethernet acces
If you are installing the router between your ISPs modem and your PC, first you will need a ethernet network adpater that installs in your PC, you will need two crossover ethernet cables, one to install between the modem and the router and one between your network adapter and the router, once the cables are connected, turn everything on, first your ISPs modem, then the router and then the PC, once the PC is up, insert the CD that came with the router and follow its instructions and that should work!
I have the same problem, and I am told by Linksys I need to chnage my mode. Vigin Media (My BB supplier) tells me I need to buy a router from them. I don't believe either of them and know there must be a way I can get the WRT54G2 to work. I have tried the solution suggested with no joy - any other offers?
