SOURCE: 2000 Accord LX, 4 Cyl. check engine light and error codes P1457, P1739
A very common late 90's code, P1457 is a failure in one of the evap
system solenoid valves. There are 2 culprits, the Vent Control Valve
& the 2 Way Bypass Valve. So, start working with those and see if you can get the 1457 code off of it.
I also looked around about the 1739 code as well which a transaxle error. However, I've found that there has been more than enough reported cases of problems of the such. Take a look at this link, and do a little reading.
http://www.hondacarforum.com/honda-2/13499-trouble-code-p1739.html
I hope this helps you out.
SOURCE: Thermostat on 2004 Honda Accord not opening, No Heat
is the heater core leaking?can you smell antifreeze?
SOURCE: 2000 honda accord lx will not start. Suspect the
Replace the starter.. The solenoid is built in..
SOURCE: Car dies while driving, now it won't start sometimes
Could be a fuel pump that is going bad. Some times when fuel pumps go bad they cavitate and pump not just gas but also air. If you get too much air in the line and not enough gas the car won't start. Have a mechanic check your fuel line pressure.
SOURCE: 2000 v6 honda accord starting problems
Need to know what type of EGR valave you have (Negative Backpressure , Positive backpressure , Pulse wWdth Modulated or ported. You can use the shop manual and *** will tell you how to Diagnosis it or write me and I will. the diagnosis is pretty simple on any type and the repair is gonna be replacement , cleaning, or bad wiring or ECU problem. keep me posted
Just to answer my own question, it appeared to be the main relay. I've replaced the part and the car hasn't had this problem since.
