Question about Polaroid TLA-01511C 15 in. LCD Television
Manual for TLA-01511C
Lost manual for TLA-01511C
Posted by olsonde on
Anonymous
  • 19 Answers
Olsonde,
Here is your product info. Please let me know if I can help you in any other way! If not, I would appreciate you rating this as "FixYa".
http://www.polaroid.com/CES/SupportProductDetail.jsp?prod_code=PT261&folder_id=0
-DRebel
Posted on Apr 03, 2009
I need the manual for a polaroid tla-01511c manual free
Try Googling (polaroid)(tla-01511c)(manual) without parens.
Sep 25, 2017 | Polaroid Televison & Video
My Polaroid TLA-01511C has sound but no picture...what do I do
Replaced the LCD inverter backlight board is dead.After U replaced this LCD inverter board.U will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board.It a long board shape.
Feb 21, 2010 | Polaroid TLA-01511C 15 in. LCD Television
I have 3 Polaroid TLA-01511C 15 in. LCD Televisions that have no picture but does have sound. Is this a common problem with this model?
I replaced three capacitors on my power supply board and the unit started working again, There was two 680uf 10v caps and one 1500uf 10v cap bad.
Nov 20, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Problems with Polaroid TLA-01511C 15 in. LCD Television
It needs a video board replaced most likely. You can find by searching on google for your model. Might cost more than set is worth. Think about new model as they are really cheap in that small size.
Feb 04, 2018 | Polaroid TLA-01511C 15 in. LCD Television
How do i find the AUX on the Polaroid TLA-01511C? I want to run a DVD player and it needs to be set up on the AUX. If I run a scan on the channels it does not pick up the AUX
I would recommend using the S-video connection for the DVD to the TLA-01511C TV's S-video. Then, press the input button and go down to the S-video option and you should be good to go - it worked for me. Hope this helps you!
Dec 21, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Polaroid TLA-01511C 15 in. LCD Television Logo
738 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
