Question about Dishwashers
Whirlpool quiet partner II top rack sprayer doesnt work
Posted by pezdel4 on
  • Anonymous Mar 25, 2014
    whirlpool quiet partner ii
Paulo
  • 188 Answers
The top rack spray arm doesn't work because of low water pressure from the wash motor or it's clogged with debris.
If the top spray arm looks clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Posted on Apr 03, 2009
  • Shelia cook Mar 25, 2012
    That did the job. Sump was full of popcorn seeds and garbage. No admissions of guilt from the peanut gallery, but lectures on it not being a garbage disposal ensued. :)
Whirlpool quiet partner 2 top sprayer fell off and won't stay on
It should lock into place. Check a parts lookup on searspartsdirect.com to see if you are missing parts. it is a easy fix unless a part is missing , you have a spray arm and a lock tabtab
Feb 16, 2013 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
The sprayer on the roof inside of my dishwasher does not work. My dishes on the top shelf are stll dirty after a complete cycle wether on normal or pots & pans. I have the whirlpool Gold Quiet Partner...
I'd look at the "spray holes" on the sprayer to ensure no clogs.
Next, ensure tube at the back (if I'm thinking of the correct model) of the top shelf meets with the spout sticking out of the baqck wall of the washer.
Jul 17, 2011 | Whirlpool Dishwashers
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
I have a whirlpool quiet partner II dishwasher. There is a gritty residue on the dishes in the top rack and on some of the silverware. Any suggestions on how to fix this?
MAKE SURE THE UPPER WASHER ARM IS NOT CLOGGED, SOMETIMES FROM DETERGENT BUILD UP IF YOU'RE USING POWDER DETERGENT. CHECK ALSO FROM THE BOTTOM IS THERE'S ANY DEBRIS THAT MAY PREVENT THE WATER GETTING TO THE UPPER WASHER ARM
Jan 16, 2010 | Whirlpool Dishwashers
I have a Whirlpool Quiet Partner II model DU1100XTPQ7. The top rack is not clean after the dishwasher runs. We cleaned both sprayers with pipe cleaner & ran water through the lower sprayer with a...
Hello Tx_smiths! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address [email protected] with your name, reviewer name (Tx_smiths), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 19, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
Top sprayer not turning, dishes in top rack not getting clean. dishwasher is a Quiet Partner II
check the holes to see if blocked with foodstuff like sweetcorn etc
Jun 24, 2009 | Dishwashers
I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Apr 12, 2009 | Dishwashers
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
1,938 people viewed this question
Top Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
