Question about Proton SRC-2010 LCD Touchscreen Remote Control
REMOTE CONTROL CODES FOR EMPREX TV
I HAVE A EMPREX TV (MADE BY PRONTO) AND I BOUGHT A SONY REMOTE CONTROL AND I HAVE TRIED ALL THE CODES AND NOTHING WORKS. WHAT CODES I NEED FOR THIS REMOTE AND TV?
IF I NEED TO BUY ANOTHER REMOTE. COULD YOU PLS TELL WHAT TO BUY.
THANKS JOHN
Posted by jsagoo on
Anonymous
Emprex uses the Memorex codes. They are 1002, 1004, 1005, 1010
Posted on Feb 03, 2010
  • fixitman10 May 15, 2011
    I have Direct TV and the Emprex codes didn't work, but the Memorex codes did for my Emprex TV. Thank you!
Mary Scott
    New Friend:
  • 3 Answers
I found a replacement remote for my emprex 3201ae on Amazon for 42 dollars
Posted on Nov 14, 2012
I bought 2008 Subaru tribeca and the DVD remote si not working so i bought a new one from Subaru but it's still not working but the unit is ok any idea?
remote volume control not working Questions & Answers ...
www.fixya.com > Forum > Tags
I bought a Philips PM3S universal remote contro today, thinking that the TV needed one specifically. After one code try, . ... Volume buttons of Sony Remote control is not working for Akai TV. ... not working for Akai TV ... Radio volume control on 2008 Subaru Tribeca does not ... www.fixya.com/. ... RCA TruFlat 27F520T 27" TV.
Media Center Entertainment for Tribeca - SB9T.com
Nov 23, 2015 | RCA 3-Device Universal Remote with...
Emprex tv LXA 42A100B model LT 42409
Check the infrared emission from the remote control first, before confirming, the remote sensor inside the TV is faulty. If you wish to get some details about how to check a remote control, check the site linked here. If remote control is found OK, then only move to replace the infrared sensor inside the TV. The failure rate of infrared sensor is very rare case. http://electronicshelponline.blogspot.com/ If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 09, 2014 | Televison & Video
I need the Emprex TV remote control code to program into my Dish Network remote control. Dish Network does not have this code.
We would be happy to help you with that. Currently the onlycode we have that will allow you to control your Emprex TV is 597. If this codedoes not work we would recommend doing a power scan.
Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer.
Phillip Chang
DISH Network Customer Service Representative
Aug 21, 2010 | Proton SRC-2010 LCD Touchscreen Remote...
No Volume.
Try another remote code for that brand tv, there are many different codes for the same make.
Jul 22, 2010 | Universal Remote Control Philips Pronto...
Philips Universal Remote Codes to program an Orion TV
hi! i have here a couple of codes for your orion tv! just try them, 1023, 1033, 1107, 1382, 1383, 1511, 1382, 3213, 1383, 3202, hope this helps!!!! goodluck!!!
Jun 07, 2010 | Universal Remote Control Philips Pronto...
Finding remote codes for Sony KDS-R70XBR2 television and Panasonic DMP-BD55 Blu-Ray player? Am trying to configure a Pronto TSU-9200 Universal Remote and their database does not show these components.
www.sonystyle.com/.../SonyStyleStorefrontAssetStore/.../KDSR70XBR2.pdf
service.us.panasonic.com/OPERMANPDF/DMPBD35-MUL.PDF -
Those two manual have the codes for each
www.remotecentral.com/ - United States
www.pronto.philips.com/library/.../DataSheet_TSU9200_00.pdf -
www.remotecentral.com/.../ind-270.htm - United States - 6 hours ago -
I too have checked exhaustively apart from the info at these links above, It appears that you may have an incompatible remote.
www.remotecentral.com/cgi-bin/codes/ - United States -
www.slingcommunity.com › Forums - <<CHECK OUT
www.universalremote.com/faq.php -
Read up from that lot it will sort you out. Heaps of help and info Visit them ALL
Mar 28, 2010 | Universal Electronics Pronto TSU9200...
Emprex HD 3202 control panel not operating
My first thought then is that the main board may have capacitor damage that will affect the boards ability to "understand" the control signals, if you can I would have the tv looked at at a service center for damaged boards and components, might be an easy fix but might not be (new boards), The lcd panel is good that can net you several hundred dollars at a min.
peope break them all the time and a simple change out is worth several hundred dollars, vs a new tv
Apr 09, 2009 | Televison & Video
Proton SRC-2010 LCD Touchscreen Remote Control Logo
5,445 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
