Question about Frigidaire Ovens
I have a Frigidaire Electrolux Free-standing Stove model number GLEFS77CSC. The top works, the clock and the timer work, the oven light comes on, and when you push bake to turn on the oven the lights come on, but the oven won't heat up.
5 Related Answers
Anonymous
  • 126 Answers
SOURCE: Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Posted on Dec 14, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
Anonymous
  • 8 Answers
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Posted on Oct 11, 2008
Anonymous
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Posted on Jun 26, 2009
Oven elements not working
you must have a hi limit thermosta (fuse) out
Aug 14, 2012 | Frigidaire Ovens
My stove works but my oven wont, and the light of the oven wont turn off
Without a model number, my guess would be a stuck relay in the electronic clock/timer. Replace the Electronic clock/timer.
Jan 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Dim temp. light
needs a new clock or find someone to refurb that one
Jun 25, 2009 | Frigidaire FEB27S5A Electric Single Oven
Light and fan come on but oven does not heat up
If the fan comes on, it will not be the timer, it will be the oven element not working.
Remove inner rear cover of oven, and you will see the element, remove screws and element, detach wires and fit on new element, be careful not to loose the wires behind rear of oven.
You may not see anything wrong with element, but the odds are that is the prob.
Please leave a fixya rating for my proposed solution.
Yhanks.
Jan 30, 2009 | Electrolux EOB5665G Ultrafan Electric...
Frigidaire free standing range
Please post the model number for he stove in question. Its harder to advise without it.
regards
Nov 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Electric Range ES200/300
there is sometimes a thermal fuse inside the caseing might have to take the top off if not then you will need a new timer be safe and unplug
Jun 15, 2008 | Frigidaire PLEB27T9DC Electric Double Oven
Ovens Logo
22 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Carew
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
