Question about HP PSC 500 All-In-One Printer
Hp psc 500 prints only after restarting computer
  • 1 more comment
  • Anonymous May 01, 2009
    My hp psc 500 is not a usb printer. It is attached to pc by the older, larger type printer cord--parallel port (I think). If I haven't used it in a while, when I go to print, it won't print. So I restart the computer, then it will print
  • shoemail May 02, 2009
    I have the same problem. The printer prints fine. But, when the printer stays on for a while, it goes into power save mode. When it does that, the computer will not recognize the printer anymore, unless I restart the computer, then it works fine once again.
    It's frustrating. I can't seem to find a way to turn off the power save mode on the printer, but, you might want to try and select "Factory Defaults", on the menu. That might help.
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    is this a usb printer?
Anonymous
    Problem Solver:
  • 11 Answers
Make sure your pc is not affected of any viruses because virus sometimes creating problem in printing.
Posted on Apr 18, 2009
Cannot delete a print job
while the computer shows the BIOS message, turn it off, wait 2 minutes. Turn on again
Apr 01, 2010 | HP PSC 1315 All-In-One InkJet Printer
Hp printer displays offline
I resolved the problem by restarting the Print Spooler service.
Click Start/Run
Type services.msc and press enter
In the Services dialog scroll down to Print Spooler
Click to select it and Click Restart Service.
The system will stop and restart the service.
Close the dialog and check your printer again.
If this fails, leave te printer on and reboot the computer.
Hope this Helps!
Feb 13, 2010 | HP PSC 1209 All-in-One InkJet Printer
HP PSC 500 All-in-one will not scan.
Try this, it worked for me.
Turn off the computer.
Then turn on the printer/scanner.
Then turn on the computer.
Start/Control Panel/Camera and Scanners
Double click PSC500
Follow prompts
Good Luck
Jul 02, 2009 | HP PSC 500 All-In-One Printer
Multiple printers printing crooked
the hp psc 500 has to be used on a ecp port only that may have something to do with it hp included the ecp patch in the cd that came with the printer. go into you bios and set the port to ecp only that might help also install another driver.
Jan 27, 2009 | HP PSC 500 All-In-One Printer
HP PSC 500 print cartridge all in one
remove both cartiges and turn turn it off make sure you put the flaps down before you turn it off. then turn it back on and insert both back in there gentle and pull down the latches slowly and carfully as to not break it and then alighn cartiges with the front panel messages touch select-resume to align them until it says copy in the front panel messages that should get it working again.
Jan 08, 2009 | HP PSC 500 All-In-One Printer
Printing does not start until I restart computer
Drivers are very good. If you will go on the website and look for the firmware(not the driver) for the printer. This is the "driver" for the printer to communicate with the signals of the computer. Sometimes, it needs to be updated if the manufacturer finds they need to be more compatible with more operating systems, such as the new Vista. Hope this helps.
Nov 30, 2008 | HP PSC 1410 All-In-One InkJet Printer
PRINTING
Will it print a self-test page and from applications installed on your computer?
Oct 13, 2008 | HP PSC 500 All-In-One Printer
HP PSC 1315 Scanning problems
download software for hp psc 1210 printer
Oct 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
284 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
