Sharp TV Remote codes, use the below codes to control your Sharp TV with a universal remote.
The 3 digit codes for most programmable universal remote controls for Sharp televisions are:
002
013
014
111
502
509
712
812
813
913
918
NOTE: Codes to operate televisions using a Sharp brand universal remote control will be 2 digits long. They will go from 01 to 18.
The 4 digit codes for most programmable universal remote controls for Sharp televisions are:
0039
0093
0165
0386
1004
1009
1011
1025
1064
1077
1078
1081
1097
1099
1153
1157
1274
1298
1311
1312
1362
1375
1378
Hi Ken, the codes are from the link at the bottom of the list...... CHEERS.. The 3 digit codes for most programmable universal remote controls for Sharp televisions are:
002
013
014
111
502
509
712
812
813
913
918
NOTE: Codes to operate televisions using a Sharp brand universal remote control will be 2 digits long. They will go from 01 to 18. The 4 digit codes for most programmable universal remote controls for Sharp televisions are:
0039
0093
0165
0386
1004
1009
1011
1025
1064
1077
1078
1081
1097
1099
1153
1157
1274
1298
1311
1312
1362
1375
1378
If these codes do not work or you have other codes that work, please leave a comment below.
0286,0261. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Pull up older posts. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Look at the manual that came with your Universal Phillips Remote.
You will see a set of televisions on a chart that will give you a 5 or 6 digit code. With your television on, select the "SET" button, enter the code for a SHARP TV, then press "ENTER". Your remote's little red LED should blink three times, at which time, you will have programmed your Universal Remote to work properly with your SHARP Television Set.
For a list of codes for the URC4110 Remote Control, go to this link, (below,) and download the manual;
SI esta utilizando un remoto marca phillip solo daja presionado code la luz se encendera luego pincha tv y con el botton de cambiar canal le das up varias veces hasta que el tv cambie de canal y luego le das enter y listo
