I took pictures with the camera when my memory card was not in. How do I get those pics off my camera or onto my memory card?
SOURCE: How do I transfer pictures onto the memory card?
Go to the camera's "setup menu" and scroll down to the last option, "move images to card" That should put the images onto the memory card.
You should be able to transfer the pictures if it has built in memory. then transfer it to memory card the same way you'd take them off
SOURCE: Need to put Pictures from Camera onto Memory Card
Hi there. Here is how you do it. Go into the menu and navigate to the Copy screen. Choose an option. One is to copy pictures from the camera's internal memory to the SD card, and the other is copy from the SD card to the camera's internal memory. Then press OK. On the next screen, you have two option choices, either copy all images, or selected images. Hope that helps.
SOURCE: Olympus FE-370
See page 34 of the manual (available for free download from Olympus below).
http://www.olympusamerica.com/files/FE-370_X-880_C-575_Instruction_Manual_EN.pdf
Or in short, select the "Setup" (tools) menu, and then select "Backup". You'll need to have the memory card installed for the transfer.
SOURCE: can't access photos
Insert the card...go into the menu and scroll to "copy". Follow the directions for copying the internal memory to the memory card.
Testimonial: "life saver! cheers mate! great help! x"
took some pics without the chip. Need to transfer the pics to the chip
