The washer fabric softener is clogged. We've washed a couple of loads without refilling the dispenser, but there is no change in the liquid level.
SOURCE: fabric softener dispenser is filled with water
I had this same problem. I found a repair manual online and found out how to get into Service Test Mode. There is a test (t12) for the dispenser motor/mechanise. Running this test basically just runs water through each of the dispenser compartments (prewash, wash, bleach, fabric softner). All ran fine - no error codes. I continued to run the test on the fabric softner dispenser repeatedly and after 5-10 cycles it started draining properly. I think a tube (or valve or opening) was just clogged with the built up softner. I also put some vinegar in the compartment a time or two just to clean out any residue. Be careful with the Service Test Mode - read directions carefully - the manual warns that if you don't get out of it corretly that it can lock up you washer.
SOURCE: clogged fabric Softener
I had the same issue, and ran vinegar through the fabric dispenser with a load of towels. Not only did it solve the 'sour towel' problem I had with that load, it also cleared my fabric softener section. Now, I water down all fabric softner when I use it, which is less frequently!
~Steph
SOURCE: the fabric softner dispenser is clogged. it fills
Pour really, really hot water into it and that should disperse the fabric softerner...then run the washer with NO clothes in it...good luck
SOURCE: GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
SOURCE: My Ge Adora washer fabric softner dispenser
Dilute the fabric softener, I was told by the repair man that this is a common problem and easy fix.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
