Question about HP Photosmart 8450 InkJet Printer
Printer Photosmart 8450. Using HP black cartridge. Received message saying the printer did not recognize the cartridge because it was not HP. Removed it and tried several times to print. Gave up and inserted a new cartridge and seems to be working fine. The old cartridge was only half used. What is going on?
Posted by Jerrine Taylor on
Rod Eslinger
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
Regarding your HP94 black ink cartridge error problem and inability to print to your HP PS 8450 printer, this type of problem is probably an internal micro-electronic failure inside the HP94 ink cartridge.
To determine which cartridge is causing the issue and/or to confirm an electrical problem with one of the ink cartridges (or possibly both), perform both the Internal Self-Test page along with the Pen Electrical tests (diagnostics) to evaluate the electrical condition of both ink cartridges....
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self-Test Page:
1. Press CANCEL and SAVE simultaneously (SAVE is the left-most button before POWER on/off.)
2. Using left/right arrow keys, navigate to 'pen electrical test'.
3. Select Enter to print test - evaluate nozzle test pattern.
-- If the printer prints the self test page then this demonstrates the printer is generally functional and that the problem is likely with one of the ink cartridges. Please note this is a 'forced' service test...the printer will attempt to print the test page whether the cartridges are good or bad. If the Self-Test page can be successfully printed but regular/normal printing cannot, then one of the ink cartridges is likely internally damaged. Remove and replace suspect cartridge to confirm.
C. Perform Cartridge Diagnostics tests using either C.1 or C.2 procedure below (varies by printer model):
C.1. Tap 41/43 Diagnostics Test:
1. To enter the Manufacturing Tests menu, press the 3 small, round buttons on the front panel simultaneously for >5secs: 'OK', 'CANCEL', & 'SELECT PHOTOS' (or 'Print Photos')
2. Using left/right arrow keys, navigate to Special Reports (or System Menu). Select Enter.
3. Navigate to 'print-mech button tap' menu.
4. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 41' (or attempt 'code = 43' if nothing prints using '41') is displayed.
5. Select Ok. Within one minute the Tap 41 (or 43) diagnostic test pattern should be initiated and print. Refer to video to help evaluate test pattern. Refer to 2nd video for guidance on how to read the diagnostic test pattern: http://inkjet411.com/?page_id=1741
NOTE 1: A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. For reference only, refer to the following HP Deskjet video which shows how to read the HP 93-97 ink cartridge diagnostic test print: http://inkjet411.com/?page_id=1741 (see 2nd video)
C.2. Pen Electrical / Error Bypass Procedure:
2. Using left/right arrow keys, navigate to Reports Menu (or System Menu). Select 'pen electrical test'.
3. Select Level 1, 2, or 3. Enter to print test - evaluate nozzle electrical test print.
NOTE 2: Pen recovery level 1, 2 or 3 clears cartridge errors, unblocking the printer to permit you to print the TEST PAGE with the normal MENU / TOOLS /PRINT TEST PAGE choice to aid in printer evaluation.
NOTE 3: Cartridge Error Bypass Message (Emergency Printing only): The Pen Recovery Level 1 clears cartridge errors and permits you to print the TEST PAGE with the normal MENU / TOOLS / PRINT TEST PAGE choice.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
Posted on Sep 04, 2013
3 Related Answers
Anonymous
  • 54 Answers
SOURCE: HP Photosmart C6100 All-In-One Printer stopped printing black ink
Please clean the print heads :
Press Setup up - Tools - Clean Print heads on the All-in-One.
If this does not resolve the issue , Reset the All-in-One.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
If issue stil persists. Contact HP.
Posted on Dec 24, 2007
jmassengill
Johnny Massengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
Anonymous
  • 4 Answers
SOURCE: HP Photosmart 2610 printer - had been using the
Have you tried replacing the cartridges all together? That worked for me. I use HP 96 and 97 cartridges.
Posted on Jun 16, 2009
I have loaded a colour cartridge a and a black cartridge into my 8450 printer and now all I get is the 05f37c2b error code apear on the screen
Please try the following:
Remove the cartridges that you just replaced. Ensure that they are compatible with your HP 8450 printer. Make sure that none of the electrical contacts on the printer or cartridges are damaged and that there is no obstruction in the cartridge port. Turn printer main power off, and then back on with the cover closed. If the error code is now gone, open the cover and install the new cartridges as described in the manual. Also, did you remove the protective nozzle covers from the cartridges?
Good luck,
GaugeMan
Mar 06, 2011 | HP Photosmart 8450 InkJet Printer
Every time I turn on my computer my hp 8450 photosmart starts up and prints a page with this message on it (USBC0$C0. I have tried everything to get the printer not to start until I want to Print but no...
This is a long shot but have you recently installed new ink? I have seen a lot of people mentioning a similar problem since the newer ink cartridges.
If yes, then print an alignment page and go through the instructions, it shouldnt (fingers crossed) happen again after that. Let me know how you get on :)
Oct 31, 2010 | HP Photosmart 8450 InkJet Printer
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
Hp c7820 printer 02 black catridge
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expected you to have installed is not right. Double check that the ink is correct against the manual or written instructions inside the printer using the number not the shape or color of the cartridge. Not every cartridge that fits the printer necessarily works.
Nov 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
It says my photosmart 8450 can not communicate with the computer, so I can't see how full/empty my ink is?
you need to re-run teh HP 8450 install again to load the utility that allows you to see the printer cartridge levels.
Oct 04, 2009 | HP Photosmart 8450 InkJet Printer
HP Photosmart 8450 won't read 4gb SD card.
Yes, you should have received a USB cable with your camera. If not, take the camera to Radio Shack for a match-up.
Jan 11, 2009 | HP Photosmart 8450 InkJet Printer
Color ink cartridge
Backup mode means printing with one cartridge. If the printer tells you "cartridge failed", it probably doesn't recognize it. You can try removing it from the printer and gently wipe the electric contacts on the cartridge with a dry cloth. Turn the printer off, turn it back on and reinsert the cartridge. If the message is still there, I suggest you buy a new color cartridge. You can also go to the store where you refilled your cartridges and ask for their opinion, they may be able to help too.
Oct 14, 2008 | HP Photosmart 8050 InkJet Printer
HP Photosmart 8450 InkJet Printer Logo
438 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
