As the fitment of tow bars to vehicles requires a modification plate to be added to the vehicle this is a job best left to the shop doing the job. Nissan currently have chassis/body failure from incorrect tow bars and incorrect fitting procedures. If the bars are fitted by anyone not qualified to do so and the bars are not certified then the owner faces criminal charges in the event of the bar failing and causing damage.
SOURCE: fitting a towbar
thank you very much for replying i solved my problem by getting an audi manual.
regards
denise
SOURCE: fitting a standard towbar wiring kit to a 1998 rover 420
There should be a wiring harness under the kick panel under either the rear of the vehicle right next to the light (plugs into adapter) or it is under the kickpanel on the passenger side of the vehicle where there foot would be next to the door under the dash
SOURCE: fitting towbar to nissan primera p10,need to know
you are not allowed to fit your own towbar anywhere in europe now ,it can only be done by an authorised agent with the necessary rubber stamps
SOURCE: how to fit towbar wiring to a 2009 volvos04
you need to have a trailer module (TRM) installed before you hookup a trailer. you can go to a volvo dealership to have this done
