Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
I need to change my routers MTU settings
Its a dynex DX-ESW5 router
i need to change its WTU settings to the recommended xbox live settings but i dont know how. i need help fast so as soon as possible email me
Posted by sully_57 on
hebiz mohammed ali
    Sniper:
  • 58 Answers
Enter configuration (default ip @ is 192.168.
Access your router’s configuration http://192.168.0.1 (this is default)
user and password (dafault admin/ and blank nothing)
Then go to the WAN option select on the lower part the MTU value.
it's 1500
try a lower value 1482 for example, 1480...
hope it helps
feed back plz
Posted on Apr 02, 2009
Can a dynex DX-ESW5 act as a print server?
No. You need a router to set / obtain an IP or connect it directly to the computer RS232 serial port. No network required, but is old school and may be difficult. Specially with MAC. You are better off getting a new router.
Jan 29, 2013 | Dynex Dx-esw5 10/100 Fast Ethernet Switch...
Tip
Xbox Live - MTU Error
Xbox 360 MTU errors
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
on Sep 30, 2008 | Microsoft Xbox 360 Console
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
Dynex-e402 change nat settings to access x-box live
Dynex DX-E402 router, changing NAT settings(UPnP) to access x-box live. go to router settings web page for router, http://192.168.1.1/, enter user name and password to access settings page. user id is usually admin this also for password. under advanced settings click on forwarding. In listed sub-catagories click on UPnp. click enable. this should solve any NAT issues with X-box 360 signing onto x-box live. dynex dx-e402 was very easy to setup.
Mar 24, 2009 | Dynex DX-E401 Router
Cant connect to internect on xbox live
Well, first you need to run the CD they gave you.
Do all the steps.
Once its finished it will give you some extra choices on the side.
Click Manual Settings.
Follow the link.
Hopefully you can find it there.
I had a problem with my WEP key and thats how i fixed it.
i dont know what a mtu is though. sorry.
Dec 28, 2008 | Dynex DX-E401 Router
Dynex mtu
Browse to the router's setup page and in Basic setup you will see MTU, change it from auto or default to 1500.
setup page address is 192.168.2.1,
Look under basic setup page.
Please remember to rate all Techs who assist you for free :) Good luck, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 30, 2008 | Dynex DX-E401 Router
MTU
What router is it?
Sep 29, 2008 | Dynex DX-E401 Router
Xbox live
You need to enter the router configuration. How you do this varies by model, but usually involves typing your gateway address into a web browser. Then, you need to assign your xbox an internal IP address and activate port triggering or forwarding (depending on the sophistication of your device) to send information on the designated ports to the Xbox.RICHARDM69
Sep 08, 2008 | Dynex 5 Port 10/100 Ethernet Switch...
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
k24674
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
