Question about Toro Lawnmower 20099 Mower Mowers Lawn
No compression when I pull the cord on my lawnmower Briggs and Stratton. What do I look for and how do I fix it?
Posted by Dit Dragon on
Andrew White
  • Toro Master
  • 2,239 Answers
There could be a whole bunch of things to cause this, from a badly worn engine to just a valve stuck open, a dealer could do a leakdown test on the engine and give a more definate reason for the problem, or you could remove the cylinder head ( side valve engine ) and check the valves are opening whilst turning the engine.
Posted on Aug 03, 2013
1 Related Answer
linvine
SOURCE: My lawnmower pull cord is stuck. I cannot start my
Need to replace pull cord
Posted on Apr 23, 2011
Craftsman gold 6.0 hp. walk behind lawnmower wont start
Back to basics, is the fuel in the tank good?( fill with fresh fuel ) does it have a spark at the plug?(remove the plug, earth against the cylinder, is there a spark,if not, replace the spark plug and try again ) does the plug wet with fue lafter pulling?( clean/service carb ) is the spark occuring in the correct place ( flywheel key sheard ) has the engine got good compression?
Aug 19, 2013 | Briggs & Stratton Briggs Stratton...
Briggs and stratton lawn mower 4 stroke engine
did you hit something while mowing the key way between the flywheel and crank shaft might have sheared it will act like the blade is missing pull back on you while pulling the rope
May 25, 2012 | Briggs & Stratton Briggs Stratton...
Lawnmower blade hit a stump now can't pull starter cord
sheared timing flywheel key replace it check to see if crankshft bent if throw it away or replace motor
Apr 01, 2012 | Briggs & Stratton Briggs Stratton...
How to remove valve from briggs and stratton modle #190702 how to remove clip, photos please
you need a valve spring compresser dont try useing two screw drivers to remove the clip use the valve spring compresser it so much easier
Jun 28, 2011 | Briggs & Stratton Briggs Stratton...
How do i replace a pull cord on a b&s 3.75 sprint lawnmower?
it is a small engine just buy a new one it will be cheaper in the long run and save yourself some trouble
Jun 12, 2011 | Briggs & Stratton Briggs Stratton...
I have a Briggs & Stratton Sprint 3.75 hp lawnmower and it seems the cord is pulled almost all the way out and won't retract. How will i know if it is broken? or should I be able to wind it back up...
You should be able to Fix this yourself if your a fair garage tinkering mechanic. However...I need the engine and type number off of the engine to get you parts information. The spring is broken in your recoil. It is a matter of removing the air shroud, taking off the pulley / spool and changing the spring.
http://www.ehow.com/video_2328977_how-install-lawn-mower-starter.html
and how to tension the spring:
http://www.ehow.com/video_2328961_how-tension-lawn-mower-starter.html
There are 2 different types of springs used so having your engine model / type number is important so that you can get the right spring. One of the 2 part numbers is: 390066
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Briggs & Stratton Briggs Stratton...
Pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
Toro Lawnmower 20099 Mower Mowers Lawn Logo
275 people viewed this question
Top Toro Garden Experts
roeb
Dennis Key
Dennis Key
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
