SOURCE: my laptop does not recognize my n97 when connected via usb
Have had many similar issue with Nokia phones & PC Suite connections - works fine then stops - in add remove programs there is an entry called PC Connectivty Solution - it does not say Nokia unless you go change then it says Nokia - remove this, the Nokia suite & Nokia Connectivity Cable Driver - restart PC, switch off phone, remove battery, switch on, reinstall and it should work.
Good luck.
