[I want to change my I P Address constantly]I want to know what kind of router that I can use to change my I P address on my desk top each time I send out an advertisement. Please reply w butler
You can use any router. All routers these days comes with a DHCP server feature built-in. However, you have to ensure your desktop is set to receive ip address and dns dynamically from the DHCP server.
However, if you wish to have the same ip address always but dynamically assigned by the DHCP server and not a static ip addres, you need to go for a router that provides static dhcp ip address.
You may check Linksys, where you could find one of their model which has this Static DHCP feature.
I hope this helps
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory
defaults. Any settings on the router will be erased. The router's IP
address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
