I have win 7 64 bit vorsion and my printer installed in win xp 32 bit ,when i shared this printer,when i try to connected this printer with my win 7 system ,it asked for,.inf driver for installed this printer,so what can i do.suggest me.
SOURCE: I HAVE HP LASERJET 1018 PRINTER. I INSTALLED &
The drivers should be the same. When you share the printer, just make your Windows Server 2003 go to the computer with the printer shared by typing the IP address of the computer in the Run Box (Start > Run), for example \\192.168.1.100\. If your XP machine is set correctly, you should see the Printer and Faxes icon, or the printer icon. Double click on that and your printer will be installed with the drivers that XP uses (which are the same, just double checked) so you don't need to do any installing.
SOURCE: HP LaserJet 1022 has been installed on a PC (WIN 7
go into the properties of your network connection, and click change advanced sharing options
Sorry for the lousy screen capt there, but you should get the idea of where everything should be set.
password protected sharing off is important
turn on network discovery is the other really important one
and of course, enable file and printer sharing.
If you get lost, post a reply here!
SOURCE: i installed hp lajerjet 3050
Same Driver will not work for win7 64 bit even if you share the printer it needs the driver for win7 64.
You will have to download the driver for win7 64bit and install in that system.
http://www8.hp.com/in/en/support-drivers.html
Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button.
Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf.
Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
Once the client maps to the shared print driver, printing should work successfully.
For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
