Hitachi RD5086P 8.3-Cup Rice Cooker Logo
Question about Hitachi RD5086P 8.3-Cup Rice Cooker
MY RD5081 RICE COOKER ONLY WILL JUST WARM RICE, WON'T COOK.
My Hitachi rd5081 8.3 rice cooker was working well, but now when you press down on button to cook it stays down with light on like its cooking but its only warming water. Can anyone please help with this problem.
Thanks in advance.
Francis from Louisiana
Posted by ctefmk on
Anonymous
    New Friend:
  • 4 Answers
The preassure switch may be not working right.
It may be corroded, etc.
Unplug the unit and push it back several times, try to see if the spring is working, etc.
Posted on Jan 04, 2011
Anonymous
Hi francis,
the heating element could be distorted or warped, therefore the contact of the switch to the bottom of the rice bowl is incomplete. Hope this helps.
Posted on Nov 30, 2012
Tony Johnson
    New Friend:
  • 4 Answers
I don't know if this helps Francis, but i have found that my rice cooker tends to do this when I plug it before I the rice water and bowl in the unit. you can try geting everything in place and then plugging it, then setting it to cook. Good Luck.
Tony
Posted on Dec 30, 2009
1helpful
What is the rice to water ratio for cooking rice in the rice cooker?
Here's a simple one page guide for cooking rice in a rice cooker. It will tell you how much water to add depending on the type of rice you're cooking - How to cook rice in a rice cooker
When I put cook button its going to warm alwayas.Please suggest me what to do. I bought just 5 months before.
You should have a button that says something like white rice and brown rice....the cook button is for steaming veggies...
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
2helpful
2answers
My rice cooker, its not responding. Panasonic SR G06. power is ok , but its just dont want to cook! why??
check replace the micro switch of your rice cooker it is the switch that is connected to the cook and warm button....check for the heating ellement it is the coil that heats to do this open the bottom cover of your rice cooker you can see a round shape fillament examin whether this fillament is not brocken and is connected to the power source
1helpful
Was using rice cooked for sometime. My cooker is not starting to cook whne I press cook button. That is there is no blip and light above cook is not coming. Whereas when I press on warm button, warm button...
In the top cover of your rice cooker there is a sensor that controls the cooking circuit. Most of the t\ime what happens is the wire in the hinge area breaks due to the opening and closing of the lid. I even had to repair my own rice cooker by cutting away the damaged wire then soldering a longer new wire in BOTH wires. I also added shrink tubing over the 4 connections on 2 wires.
Tiger rice cooker
There is a sensor that regulates how hot the cooker gets and shuts it down to the warm setting when it senses that the heat is too high...meaning that all the water has cooked off....my guess is that the sensor failed and as far as I know it is not replaceable.
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
I got this rice cooker as a gift, but will not work.
I had the same issue with my tefal cooker.
It may be that the bottomof the pot is a little bend in and it you can push it out a little, it may then push the thermostat down the required distance
Marco
Rice Cooker promaturely pops up before rice is cooked
try adding a little less water, And letting it sit about 4 min to make sure the steaming has stopped
Cook/Warm switch sometimes not working
I just fixed our rice cooker with the same issue - turns on and warms, but won't stay in 'cook' when the lever is pushed down. My solution was: the pot that goes inside the rice cooker was dented on the bottom and was not pressing down on the mechanism at the bottom of the cooker. Once I flattened the bottom of the pot, it works!
Top Hitachi Kitchen Appliances - Others Experts
David Shaub
Marvin
Marvin
Narseman
Are you a Hitachi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
