Question about Gemini Sound Products Jeva 54" Tripod
I have a Jeva 60" tripod that i need to get a ouick release replacment
SOURCE: quick release plate for quantaray tripod
Here is the response I got for tripod parts:
The panhandles you need for the cost $5.95 each + $4.40 shipping and handling. The item #'s are TP1-62099-33001 and TP1-62099-33002. For two the total would be $16.30.
You can send a check or money order made out to ToCad America or you can call with a Visa, American Express or Mastercard number. Our address and phone number are listed below.
Thank you,
Gloria
Gloria Hoerr
Customer Service
ToCad America
53 Green Pond Road, Suite 5
Rockaway, NJ 07866
Tel: 800-886-2236 ext.119
[email protected]
Hope it helps.
Posted on Jan 03, 2008
SOURCE: Missing Tripod piece (Quick release)
What you can do is find a local welder or metal shop in your area. Take the tripod with you, and ask them to fabricate a aluminum or steel replacement "shoe" for your tripod. Also have them drill a hole in the center so you can later insert the proper threaded screw that will mount to your camera. You may want to take your camera and get the proper threaded bolt first before you get the shoe made, so they can make the hole the correct size. You can go to any hardware or home improvement store and ask for assistance to find the right thread for you camera equipment. The bolt should not be any longer than1 inch, so it will mount tight on your plate.
** Note you want a flush mount type bolt that when tightened on the plate is smooth on the bottom** This is so when you mount the shoe in the head, it will be properly seated.
Posted on Aug 04, 2008
SOURCE: need a quick release plate for Dynex tripod 60
The Velbon QB-4W Quick-Release Camera Platform is a nearly identical replacement for the plates that come with the Dynex DX-TRP60 tripod. You should have had a spare in the bottom of the tripod bag when you bought the unit. The Velbon QB-4W is available at many on-line sources for about $5.95.
Good luck,
Swarf
Posted on Nov 20, 2008
SOURCE: Missing tripod quick release plate for AMBICO v-0552
Try www.TripodQuickRelease.com They stock a 41mm and a 45mm plate that may fit your tripod.
Posted on Feb 10, 2009
SOURCE: Kalimar tripod
Product code # QB-5LC made by VELBON is currently available at TRIPODQUICKRELEASE.COM for $10.99 ea.
Hope this helps.
Posted on Mar 24, 2010
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen.
I have a Jeva 60" tripod that i need to get a quick release replacement
Need the part that attaches to the camera.
