I have a RCA WHP160T Wireless Headphones set. But I havn't used it for quite some time and I have misplaced & forgotten what the output voltage on the Power Supply Transformer is. Could someone Help me? Thank you!!! E-mail: [email protected]
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
well if you dont have the instructions, how the hell we gona help you? what you need to do is go around that house and find out who took it or misplaced it, cause crying online about it is not gona hlep you, so get up rite now and raid your house, WORD!
Hello. Yes it can be fixed. Take your headphone to any radio shack store and show it to one of the technicians there. They will show you the component you need to make the repair. Many times, a dab of one minute clear epoxy will mend too. Regards, Joe
Hi Trapper John...you sound pretty frustrated so I'm just going to offer a single, and easiest method to achieve your goal.
Purchase a 1/4" (6.3mm) Stereo Jack to Stereo RCA Plug Cable. If you have difficulty finding this cable as I have experienced, you may purchase it from the following website by clicking on the URL below:
http://www.zzounds.com/item--HOSYPR102
Once obtained, plug your Wireless Headphones into the 1/4" Jack, and insert the RCA Plugs into the Zone 2 Output on your Receiver and your dreams will be realized. Instructions and information on Zone 2 may be found on page 82 of your Owners Manual....good luck my friend.
If I remember this tv correctly, check under the audio setting in the menu, most tv's including this on have variable output for the audio o/p. meaning the the o/p vol. is adjusted as the tv speaker vol. changes. some tv's will put out a fixed audio o/p to the rca jacks, but will only do this when the speakers are shut off in the menu (not muted, but off). I have run into this problem many times & have yet to find a better solution to getting a steady sound sound out of the o/p jacks.
