Question about Coby DVD-937 5.1 Channel DVD Player/Receiver Home Theater Speaker System System
Coby surround system volume will not turn down
3 Suggested Answers
6ya staff
SOURCE:
bbl242003
Bruce lee
  • 1637 Answers
SOURCE: i have a coby dvd/cd home theatre system i have
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
Posted on Jan 16, 2011
bobandres57
Bob Andres
Okay thank you
Posted on Sep 28, 2015
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
Jan 06, 2016 | Audio Players & Recorders
Unlock coby mid7048
  1. Turn off the unit completely.
  2. Press and hold the volume down (-) button.
  3. While holding down the volume down (-) button, press the power button to turn on the unit. Once you see Coby logo on the screen, you can release the power button, but you still need to keep holding the volume down (-) button until you see Android robot logo on the screen.
  4. The "Android system recovery" menu will appear on the screen. The volume up (+) button is used to scroll up in the menu list, while the volume down (-) button is used to scroll down. The power button is used to select and/or enter an option.
Jan 03, 2013 | Coby Kyros Tablet
I have the coby 765, when i switch the buton to tv it is very loud even with the tv and dvd player turned completely down
Unfortunately the subwoofer should have a volume control knob, and the subwoofer for the DVD765 does not have this, that is why it is so loud, the only work around is to get an audio cable with a built in volume control knob.
Oct 27, 2012 | Coby DVD765 Theater System
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
I have a coby dvd/cd home theatre system i have hooked it up to satellite but when i turn it to tv the volume can't be controlled only can lower volume in dvd mode not in tv and the tv remote can't turn it...
Welcome to fixya
Hello
Jan 16, 2011 | Coby CSP92 Theater System
I just bought the coby csp96 surround sound package and am having trouble hooking everything up. It came with the dvd player to hook all the input cords to, which i did. Everything is working accept when i...
there is a nobb on the subwoofer, one is to dial down or up the sub (noob1) , and the other is to dial up or down the 5.1 speark (noob 2). turn noob 2 to the left to dial down the sound, first time i got my setup it was totally down, btw the 5.1 works wonderous if you use a home theater system. Iam using a 1,000watt sony home theater system. 100/200watt RMS per channel at 5 channel those little speakers really can handle well, I never experiance any blow outs :) Coby outdid themselfs with this system
Sep 05, 2010 | Coby CSP-94 Speaker
Low sound when turned to AUX for surround sound
remember to turn the volume up on the cable box and down on the surround sound so you will get max audio input to the surround system and then adjust using the surround sound remote! good luck
Jan 11, 2009 | Panasonic SC-HT680 System
Does remote have audio volume adjust?
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, the dvd 224 doesn't have a volume adjustment. The models that do are the ones that come with 5.1 surround sound speakers such as dvd 755, dvd 937, and dvd 958 just to name a few.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 20, 2008 | Coby DVD-224 DVD Player
Am I forgetting something?
Your old TV took off the sound before the volume control and the new one takes it off after that control. Not much you can do without going in and doing some rewiring. You could use a VCR for your TV tuner source and then you would be able to turn down your TV sound and still get sound to your surround system. Good luck.
Feb 02, 2007 | Sony HTD-DW760 System
Open Questions:
See all Coby DVD-937 5.1 Channel DVD Player/Receiver Home Questions
150 people viewed this question
Top Coby Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Joe Negus
Joe Negus
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
