SOURCE: System will not power on!
My system seems to be locked in stand-by. When I unplug and replug the red power light comes on, but bwhren pressed just starts blinking like in stand-by. Help
The fuse has blown out and some CAPACITORS ON THE POWER BOARD. You will need to replace the fuse first and then look for blown out capacitors on the powerboard using a multimeter... Just in case you locate the faulty capacitors just note down the values on them and google for them. Shouldn't be hard, anyways if can't find them i will be right here to help!
Regards!
Eagle.
SOURCE: phillips stereo won't power up
Leave relay alone! check those big fat transistors , usually shorted...
SOURCE: my Philips HTS3410D will not
Mine was exhibiting similar problems. It was the electrolytic capacitors in the power supply board.
There are 4 or 5 of them, and between 2001-2005 there was a bad batch of capacitors that came out of the far east, some of these capacitors were inferior quality so they dry out and fail. You can read about them on badcaps.net You can usually tell a failed electrolytic because the top cap puffs out slightly. Mine were actually almost pointy on top.
If you have the dexterity, soldering pencil and time, you can fix it yourself for about $5.00. Be warned that as soon as you open the case, you void the warranty, so if you don't feel comfortable, take it to a professional. Also, My remote is dying, so if someone wants to sell me their remote, let me know.
