Question about Epson Stylus CX3200 All-In-One InkJet Printer
Epson sx200 One of the colour inks is empty and no print in black
One of the colour inks is empty and because of this printer dont wants print in black.I chosed option print in black only but still printer prompt that one of the colour inks is empty and cant continue printing! please help printer is epson sx200
Posted by bmw525525 on
  • Anonymous Apr 27, 2009
    my homework is in for tomorow and i cant print anything please hlep
  • Anonymous Mar 26, 2014
    not printing in B&W
Anonymous
  • 163 Answers
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Posted on Apr 02, 2009
  • Sommer Heimo Nov 06, 2013
    Negative, I have 2 T1100 printer and the problem is on both, I think it is an setting issue, because on "Text and Image" the black is nice but the overall result is not good enough
  • malcolm andrews
    malcolm andrews Mar 05, 2014
    the inks are new and there is no colour degredation across the 4"x4" print. So I cant se that it is an ink issue. I agree with Sommer Heimo in that it is a settings issue, but I cant find anything that explains what is necessary.
etrc_new
    Master:
  • Epson Master
  • 752 Answers
Maybe one of your colour cartridges is low or empty
see https://uk.answers.yahoo.com/question/index;_ylt=A9mSs2g8xzJVZaoAnGJLBQx.;_ylu=X3oDMTByam1ucWFtBHNlYwNzcgRwb3MDNwRjb2xvA2lyMgR2dGlkAw--?qid=20101221123853AAwzTvq
particularly this reports
"I just checked the Epson website for this printer. The documentation says:
"You cannot continue printing with one ink cartridge expended, even if the other cartridges still contain ink. Before printing, replace the expended cartridge." "
18.April.2015
Posted on Apr 18, 2015
Ho do i know which ink cartridge is low
Hi
the easiest way is to send a print job to printer. If any cartridge is empty, the printer should refuse to print and display an error message. This should indicate which cartridge is empty/not recognised - with a red X above the empty colour. Another way is to go to 'printer properties' then 'maintenance' page and click on 'Status monitor' button.
Hope this helps & good luck with it.
Oct 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
BLACK INK NOT WORKING
Black ink head clogged/cartridge empty. Go to Printer Utility and do a Nozzle Check, Print a Pattern. If Black pattern lines are missing/broken then do another cleaning. Don't forget to try a new cartridge if the cleanings do not work. Refurbished Epson printers are great and can be purchased at www.epson.com/clearance. I have used them for 15 years.
Feb 15, 2013 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
I have a new black ink cartridge but my printer wont print because the color ink is empty is there a way to get it to print without refilling the colored ink since i only need black???
When printing in BLACK, a small amount of the COLOUR ink also is used.
This "trick" prevents the COLOUR ink-jets from clogging, due to not being used.
So, you need to have a "good" COLOUR ink-cartridge.
Mar 18, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Can't scan when out of ink
Unfortunately, there is no way to print with your printer without replacing
the empty cartridges. Sadly, that's just how Epson printers work.
Jan 16, 2010 | Epson Stylus CX5800F All-In-One InkJet...
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
One colour cartridge on epsom sx200 is empty yet it wont allow me to print in black only
umm... this is not a solution because I don't think there is one apart frombuying new inks. Epson and all other inkjet printers do this to preventthe coloured print head nozzles from getting blocked. If they are notused for a long time the ink dries up and blocks the nozzles. Epsonrecommends printingat least once a month with all colours to prevent this. Printing inblack only option will only work if the colored inks are OK. Wheneverthe printeris turned on it performs a head clean, this is why the coloured inksget used over time even though they are not used for printing.
www.Quikshiptoner.com
Nov 25, 2009 | HP LaserJet 2840 All-In-One Printer
My epson stylus SX200 2C will not print black , i have replaced the ink 3 times and cleaned it - it has a lot of gaps and sometine doesn't print black at all. Colour is fine. Help please .
I have excatly the same problem. I have cleaned the nozzles mutiple times and replaced the blck cartridge twice but I still have patchy printing in the black portion of the test print and horizontal banding in word documents
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
2,978 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
