LG RU-23LZ50C 23 in. HD-Ready LCD Television Logo
Question about LG RU-23LZ50C 23 in. HD-Ready LCD Television
Not operating SIZE button
Hello. I have a problem. In TV LG 21fs2blx not working szie button. Please teach me how to use that button. I'll waait solution. Thanks.
Posted by kamikadze01 on
  • kamikadze01 Sep 02, 2007
    Please help me !!
Anonymous
I think you must press size button more times
Posted on Jul 21, 2008
1helpful
Sanyo TV Code for Dish remote 21.0 IR/UHF PRO only operates TV Power and Volume Functions.
Hello Witt Thomas,
I can understand the concern and wanting the remote to work the TV Menus. It is possible with our remotes, however it depends on the TV itself. I've seen instances where there are 2 TV's in one house, and 1 will do it, while the other won't.
If you have tried all of the remote codes, and none work, the only other options we have available are to try a powr scan, or teach the remote. This link http://www.mydish.com/support/teach-learning-remote-20-21 can provide the steps on how to teach that model of remote control!
Let me know if you have any other questions.
Tommy Faust
DISH Social Media Representative
1helpful
2answers
Hello I'm finally back again I got a customers LG tv Model #37lg30 it does not respond to the remote the buttons on then side alow us to operate the tv I tried the remote on another
Check on the back of the TV to see if you have a "remote in" port. It will look the same as a 3.5mm headphone jack. Unplug the TV and plug a pair of headphone into the port and then remove it. Do this several times to breakup any debris that may have gotten into it or corrosion that may have occurred in the port. If something is in the port it will disable the standard remote sensor on the TV.
Hi i need to find a sky plus code 47lh300-za for this LG TV can you help?
Hello
Setup codes for LG TV with Sky are:
065 244 405 318 037 398 191 459 245 389 060 275
065
742
743
726
508
584
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4*Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
1helpful
2answers
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
7helpful
Just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Sky TV REMOTE WILL NOT WORK MY LG tv RZ 37LZ55 ,NEED A CODE ....TRIED ALL CODES NON WORK !!
Hello Kenny
Please follow the steps below with you Sky remote.
TV,
RED + SELECT (flashes twice)
TV
0056
Try the volume button if this works then press the SELECT button on the remote. If not press the TV button and try the volume again. repeat this step until the volume works the tv then remember to press the SELECT button to save the code to the remote.
If for any reason this does not work then what I would like you to do is take the battery cover off the remote. You will see a label on there stating what REV 4,6,8 it is. The numbers indicate how old the sky remote is. If your LG telly is a newer tv then you may need to purchase a newer Rev sky remote.
The above should sort you out no Problem Kenny
When it does please leave a thumbs up
Cheers
Little Dish Fitter
3helpful
Sky remote codes for lg32lh4000
Hello Rubel
please follow the steps below:
TV
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
LG LCD TV Remote won't scan DVD
when you are teaching it, dont just hold down the transmitting remote button, instead press it on/off as fast as you can. This may help
Not operating SIZE button.
Try going to menu, find video setting and play with different settings until it goes back normal.
TV LG 21fs2blx not operating SIZE button.
Try video menu settings and play around til it is back to normal.
Ekse
Muzahura Frank
