Hi There.
this is all i could find out from the internet so not sure if this will help you out.
(I went into BIOs again after I looked the SATA port over on the motherboard. The SATA ports on the motherboard are listed as 0,1,4,&5. In BIOS the SATA ports are 0.1.2.3.4. & 5. I have been trying to turn on 2 or 3 as they are the next ports and never tried 4 or 5.
When I turned on 4 and 5 everything is working fine.
Why do they list SATA ports 2 and 3 when they are not present on the motherboard)
or see if this link helps you.
Dell Optiplex 755 2 sata ports 2 3 not working on motherboard Google Search
SOURCE: Dell Precision 470 Dual Processor
enable "auto" in BIOS for drive #0 and drive #1. you can select IDE or SATA drive. restart the machine.
SOURCE: dell optiplex 755 does not recognize the dvd-rom
Try the fix listed here - the Fix It image.
http://support.microsoft.com/kb/314060
SOURCE: Dell DimE310 wont reeboot
try this unplug your machine,take off the side cover,there is a jumper near the battery for the cmos,it has three pins,remove from pin 1&2
and place on 2&3,remove an return to the original position.
plug in and restart,at startup press F2,scroll to boot sequence and press enter,change order to (1)CD,(2) IDE hard drive(3) SATA hard drive,save and exit.
SOURCE: Will the Optiplex GX280 support a 1 TB SATA drive?
go to bios select autodetect on hdd then f10 and restart that will fix ur problem
SOURCE: Dell optiplex will not recognize hard drive
Is it SATA or IDE? Have you tried another cable? If it's IDE, have you checked the jumper settings (usually Cable Select is easiest)?
