The dryer should be on a dedicated circuit. Is anything else on the same circuit? Try plugging the dryer into a different circuit and see if it still trips the breaker. The breaker trips because there is either a short or too much power is being drawn for the size of the circuit. Check how many amps the dryer uses, and make sure the circuit is rated for that load. If the dryer needs a 20 amp circuit, and the circuit it is plugged into is only a 15 amp circuit, that will trip the breaker.
If all that is good, there is a problem with the dryer, either a short or the motor is drawing too much power, which usually means it is at the end of it's useful life and need to be replaced. If you are handy, there are sites you can go to which will show how to remove the motor. There are appliance parts stores which will test your motor, and sell you a new one if you need one. I have a 30 year old dryer that still runs, with it's 4th motor and 5th belt, if you are handy. The cost of a repairman to come out is probably not worth it after the dryer is about 10 years old, better to replace the dryer at that point. The new ones are much more energy efficient and do a better job than the older equipment, so they are worth the investment.
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
SOURCE: Dryer just says beep beep beep everytime I push start
sounds like you may have a bad door switch(mach thinks door is open when it is not).open door and look on front panel that door pushes into.you should find a small button covered in a grey rubber boot.push on it and listen for a click,if u dont hear a click the switch is bad.if u do hear a click it could still be bad or you can have a open thermal fuse
SOURCE: LER4634E WHIRLPOOL FRONTLOAD ELECTRIC DRYER WORKED GREAT
If you have a access to an AC voltmeter, measure the two slanted connections in the wall socket for ~220 volts. If near zero, measure at the load side of the dual breakers for the same voltage. If still at or near zero, one of the breakers has gone south. Replace the pair of breakers.
If you measured 220 volts as above, then the problem is within the dryer--probably a burned out heating element or open thermal fuse. Major tear-down to find and fix as the heating element is behind the drum.
SOURCE: whirlpool gas dryer no heat
One the terminals on the flame sensor fell off. II guess this is a common problem. relaced the sensor and
I'm back to drying clothes.
SOURCE: Gas dryer tripping breaker when plugged in.
I have the same exact problem. Dryer works great....when empty. Put wet clothes in and 3 or 4 hours later they are as wet as when I started. I am going to kick the piece of junk to the curb and go get a GE dryer right now.....I suggest you do the same.
It is on a dedicated circuit and I have had no issues running a dryer here for 9 years. This dryer is 2 years old. I hate to think it is shot already. Do you know how I would check for a short in the dryer?
