SOURCE: tv will not change channels
Sounds like an eeprom problem or a microprocessor problem??? Also make sure the tv didnt lose its channel memory by reprogramming the channels feature in the menu. Good Luck
SOURCE: tv sensor for remote doesnt work
1) solder bad connects on remote sensor mounted to front edge of circuit board or, if necessary
2) Replace sensor Tosh # 23009490 ...........................T.
SOURCE: orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
SOURCE: Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
SOURCE: how to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
