Question about Toshiba e800 Pocket PC
Where i get drivers of toshiba poket pc e800 - Toshiba e800 Pocket PC
  • Toshiba Master
  • 13,434 Answers
Hey,
you basically need active sync.
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
noting else, active sync contains the driver.
Thanks and good luck.
Ekse
Posted on May 05, 2009
Toshiba e800 freeze ups...
ctrl q will close the program
Oct 24, 2007 | Toshiba e800 Pocket PC
Using a host cable
I have also found out that this cable will work just with e400 and e800 models. If there is no specification that says that this cable can be used with your PDA it will be a risk to buy it.
Sep 11, 2005 | Toshiba e350 Pocket PC
Can I downgrade fromWM2003 SE to old WM2003 Operatings System ?
Yes it´s possible to downgrade your "Operating System". You just have to download your old WM2003 Version from the Toshiba Homepage ( http://eu.computers.toshiba-europe.com). Then look on "Support & Downloads" there you find the Category "Download driver".
Sep 08, 2005 | Toshiba e800 Pocket PC
Toshiba e800 perform hard reset after changing battery
At first you should assure that the backup battery is definitely charged. I suggest to charge the PDA a hole day without using.
Internet access via bluetooth
I don't have a PDA, but I'm working much with Bluetooth in my Toshiba Notebook. So I found a interesting link from Toshiba about Bluetooth. Perhaps it helps you! http://aps.toshiba-tro.de/bluetooth/
About installed software..
I think that “Microsoft pocket pc 1996 - 2003 os” called now “Windows Mobile 2003”. To upgrade your PDA to 2003SE please go to TOSHIBA Site http://www.toshiba-europe.com/. Than go to Computer systems. Under “Support &Downloads” there is option Download Drivers. Please chose your PDA and there are all useful Drivers for “Windows Mobile 2003 SE”. In every zip File there is “Upgrade Guide”. Read it. It can help you to make update without problems.
E800 spontaneously resets
this hard reset is based on a slack joint. You could test it, if you turn your PocketPC on, and tip on the cover, near the Display or the Battery. If the PDA make a reset, your Pocket PC need a repair.
E800 with bluetooth card 2
It is very strange. The only thing that I can recommend you is to check Toshiba Bluetooth download page and check for stack update or FAQ page. Check it on http://aps.toshiba-tro.de/bluetooth/
Compact Flash card compatiblity
I don’t know why you PDA can not read your card but I found some infrmations about parts which are compatible with e800. As far as I know this types are compatible with e800. Compact Flash Memory Card 1GB (PX1076E-1NME) Compact Flash Memory Card 512MB (PX1075E-1NME)-Type I Compact Flash Memory Card 256MB (PX1074E-1NME)-Type I
Toshiba e800 Pocket PC Logo
505 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
