YouTube Videos Logo
Anonymous Posted on Aug 02, 2013
I have a 2005 V70 Volvo estate with a HU 850 6 Disc CD system. 2 Cds are stuck in the machine. How do I access it to repair the problem?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 03, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
76
Points
I need a Volvo HU-850 CD HEAD UNIT
possible scrap yard
check your nearest volvo scrap yard
HOW DO I FIX A HU 850 CD PLAYER IN A VOLVO S60 2006 ERROR
You may just need to clean your device..
if that doesn't work...maybe you can ask a car radio installation company. Dealers will problem charge more.
I need a scamatic to install a used HU 850 stereo with nav into my 2006 t5 s60
Unless you are a master automotive electrical engineer, or a volvo service tech with mainline access, this will be lots of trouble. The original head units for volvos were flashed at the dealer or factory to each individual car. Even if you got all the wires to match up between years/models, you would still need to take the finished rig to a dealer or specialist to get it "relearned". Plan on spending hundreds of dollars no matter which way you go.
1helpful
What does the error code PO300B refer to in a volvo 1996 850 GLT?
Hi, the code refers to Random/Multiple cylinder(s) - misfire detected.
Possible causes:
Spark Plug(s), HT Lead(s), Injector(s), Ignition Coil(s), Low compression, wiring.
1helpful
How to changehead light bulbs on volvo v70
To gain access to the bulbs, you need to go under the bonnet (/hood) and remove the housing cover on the reverse side of the light units.
Should just be a simple clip, but make sure that it doesn't fly out of your sight;)
Relatively simple for the rears too.
Just plastic covers on the reverse side of the units, with clips that could break, if you are too rough with them.
Have fun.
3helpful
Odometer does not work
This is a common problem with all models of volvo, with the non digital odometer  pre 1998,, there is a tiny nylon gear deep inside the odometer that needs to be replaced. Your dealer will not fix it, but will put in a new one for you as the cost of fixing in labour is more than a new one,, My solution is much cheeper,, I have
many low milage VOLVO odometer/instr clusters, a few hi'r km 1s
ODOMETERS FROM 1987-PRESENT
I have many pre 1998 Volvo instrument clusters, most with Very low milage, almost all in Km, I have most models of Volvo.
at these prices IT'S A GOOD IDEA TO HAVE AN EXTRA ONE , comes with detailed instructions -with pictures-on how to remove your old one and re-install
just for example
I have 4,, 1994-1997 850/s70/v70 /c70turbo with less than 10,000 km
2 1994-1997 850/s70/v70/c70 non turbo with less than 10,000 km
1 1990 740 -940 turbo with less than 4.000 kms
I also have many Volvo instrument clusters from 1987 to PRESENT with varied milage,,let me know what year and model and milage you are looking for,, I will have something close
WILL SHIP ANYWHERE IN N.AMERICA
Will volvo 840 doors be good for my s70
850 doors will not work on v70/s70. 850 has more slanted windshield angle, and 850 window controls are in console, so no power window harness!
2answers
How to get cd player to work on Volvo 850 1994
do you have a cd changer or is it the cd/radio .just a thought the cd button on the radio will only work of you have a changer fitted usually in the boot
2helpful
HU 850 CD stuck in player
One thing about Volvo CD player/changers...they tend to not like burned CDs and even more, burned CDs with labels on them.
I'd suggest against trying to get it out yourself.
You can get it replaced and the dealership should have a form so you can get your CDs sent back.
Top YouTube Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
 Grubhead
Grubhead
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
