Tomtom GO 300 GPS Receiver Logo
Question about Tomtom GO 300 GPS Receiver
Tomtom 300 the unit wont work, but the green light is on when connected to the external power supply
Posted by pcartera on
Anonymous
  • 4 Answers
Hello, replays those 2 smd ic's and the tomtom will work again!!
best regards
alex from holland
Posted on Jan 20, 2008
Anonymous
    Scholar:
  • 143 Answers
Have you tried resetting the unit?
small pointy object in the hole marked 'reset.'
failing that...
http://www.tomtom.com/support/index.php?Lid=1
Posted on Dec 15, 2007
Tomtom1version3 power on light on but will not switch on. Same problem using mains charger or in car power supply.Also computer is not picking the unit up as an external device
I'm afraid you have the green light of death. This happens when the car charger delivers more power than the TomTom can handle and it blows a couple of diodes.
2answers
We have bought a tom tom 910 its about threeyears old it worked at first but now it wont work at allthe green light wont come on all the time to
Try doing a device update while connected to tomtom home, if that doesnt work backup your device onto your commputer and try reinstalling the software and maps ect onto your device.
Tomtom wont come on
More than likely the negative post on your 910 is not making a contact. This is a known problem for the X10 series tt's. It can be fixed but you have to disassemble the tt to do it. No just replacing the battery won't fix your problem. If it was just a battery problem your tt would still boot up if connected to external power.
My tomtom go
hello, this problem and answers is covered under the TomTom Go 300 section. Please take a look there to get an answer. Its very comprehensive.
1helpful
Wont turn on
" I HAVE A TOMTOM GO 300, THE GREEN LIGHT COME ON WHEN PLUGGED
UP. BUT WILL NOT TURN ON. I HAVE DONE THE RESET PROCEDURE.
TOMTOM GO NOT SWITCHING ON
Hit reset button.
How old is the GPS?
Please give model and serial number to:
[email protected]
Seagate 300GB ST3300601U2-RK
usb cable provides power to your hard drive.
try to use new cable.
hopes it works.
pls. confirm
1helpful
2answers
Tom tom 300
If the unit is still under warranty, send it back to Tomtom. Even if the unit is no longer under warranty, complain to Tomtom. There is a problem with the CLA (cigarette lighter adapter). It can cause internal damages to your Tomtom. What happens is that there are three wires in the CLA along with a voltage stepdown circuit board. The wire are +, -, and a signal wire. If the signal wire get disconnect the voltage could spike up to 12vdc. The unit is designed for only 5vdc.
If the unit is out of warranty then try the following website for repairs. They can fix the two chips which usually blows.
http://www.satnav-shop.com/
Top Tomtom GPS Experts
Ekse
David Shaub
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
