Winodws xp can not compatible driver from installation CD
When i installed my LBP2900, windows xp found new hardware, but installation could not complete. In installation CD no driver compatible to windows xp.
have you looking up are you software is compatible with your Operating System. Commonly software not compatibility on 32Bit but installed on 64Bit. you must check them.
This procedure demonstrates how to install Windows XP Professional.
The procedure to install Windows XP home edition is very similar to the
professional edition. Since Windows XP Pro is more advanced operating
system, it will be used to demonstrate the installation procedure.
The
best way install Windows XP is to do a clean install. It is not
difficult to perform a clean installation. Before you perform the
installation I recommend that you check
to ensure that your hardware is supported by XP. If your hardware is
not on the compatibility list you can check your hardware manufactures
website to download the drivers for Windows XP. Save all the necessary
drivers onto floppy disks or CD before you start the installation.
plug the web cam insert your cd drive go to control Panel Add remove Hardware click next check yes I have Already connected the hardware. click add new hardware device. search for new hardware automatically.
Yes, you can upgrade to windows XP but it will require upgrading the memory to the maximum supported memory of 512 MB. It is set up with PC100. I would suggest going with PC133 when you upgrade the memory. Be advised though that the PC100/PC133 memory is expensive new but you can usually shop around and find it used for a cheaper price. The 800MHz processor will support the XP operating system.
Check that the driver is compatible with your operating system Vista or XP. My card has 2 type of drivers 1 for XP and the other for Vista You may be trying to install the wrong one
The general install procedure for USB devices is to install the drivers/software first then connect the device. The PC should then detect and initialize the device.
I however recommend you check and follow manufacture's guidance/steps.
If you don't havethe drivers/softwrae, download the drivers/software from the link below.
If your OS is XP SP2, you can un install the Graphics card via device manager and on re boot let Windows new found hardware wizard pick it up and it should set up your Card itself, as the CD's drivers are probably not the latest XP SP2 compatible driver.
You could also go to the Graphics card's Manufacturer's Support site and download the latest XP compatible driver, or whatever OS's driver you require.
You can look here also: http://www.fixya.com/support/appian_graphics
