I have some AmCam Japan 580 lenses that are for Nikon L35AF..I need to know if there is a converter for this type of lens so that I can use on my Nikon D40 and if so, where can I find one?
I don't think so. Those were wide and tele lenses for one of the first 35mm point and shoot cameras, and they snapped on over the existing lens
Posted on Aug 04, 2013
SOURCE: Nikon D40 LCD screen.
Since the camera is an SLR, (single lens reflex), the CCD image sensor is behind the shutter until you take a picture. Sorry, but you cannot use the LCD to take pictures.
Posted on Dec 26, 2007
SOURCE: Nikon D40, how to display the date.
Bring up the photo on the camera. Press up or down until you get the histogram (yellow graph). When you get this, press up once, and look at the bottom of the screen.
Posted on Mar 15, 2008
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
Posted on Jun 01, 2008
SOURCE: Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
Posted on Jun 06, 2008
SOURCE: how do i remove histogram from nikon d40 display
with the histogram visible on the screen, simply press the "down" arrow on the navigation dial. This will scroll through several on-screen options, until you get back to the playback screen you want
Posted on Jan 18, 2009
