Question about Yamaha Mg3214fx 32 Channel Mixer With Fx System
We've got a signal on the mg32fx14 mixer from the microphone. There is no sound from the speaker. We tried the Group out there is no sound. So where do we connect the output from the backpanel of the mixer to the EUROPOWER EP1500/Ep2500 amp.please. Is it from the group out, group ins or send aux. or returns 1 and 2.
Posted by crystalaeroa on
Anonymous
    New Friend:
Mg32fx14 monitors intermitently cut off, smoke comes out the back . aux 2 changes aux 1 and aux 2 at same time. 1 channel will over drive then change channels without changing enything else and its ok eny ideas or do i have a boat ancor
Posted on Jan 13, 2011
How to connect it ?
Instructions
    • 1
      Place your mixer in a location that will allow you to hear the sound coming from the speakers clearly. The best placement is opposite the speakers, centered between the left and right pair. Connect the power supply to your mixer.
    • 2
      Connect the female end of an XLR cable to a microphone. Run the other end of the cable to your mixing board. Plug the male end into the "Mic" port of an open channel. These channels provide the preamps that will shape the sound characteristics of the microphone signal, processing them for output. Repeat the process for each microphone in your rig
    • 3
      Connect one end of a balanced 1/4-inch cable to the left channel jack labeled "L" found on the "Main Out" panel. Connect another cable to the right channel jack with the "R" label. Connect the opposite end of each cable to the matching left and right inputs on you amplifier.
    • 4
      Power on your mixer and amplifier. Test each microphone connected to the mixer for output.
    • 5
      Adjust the volume of each microphone channel to create a balanced mix. Use the "EQ" knobs to shape the tone and cut out frequencies that are causing squeal and feedback.
    • Audi Performance Chip
Jun 19, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
Hi, I'm dealing with a problem on my Mackie ProFX 8 mixer. For no reason that I can discern, I am simply not getting any signal out of the mixer. I've adjusted the appropriate levels and gains,...
Are you getting signal into the mixer? Do the level meters light up?
If so, check your speaker cables. If not, check the mic cables and mics (try with phantom power on and off).
Also, try plugging a speaker into an Aux out to see if you can get level out of that.
Hope that helps...
Jul 01, 2011 | Mackie ProFX8 / SRM450 V2 PA Package
I loaned my fender passport 300 to some friends. They said they ended up using it as a mixer on a larger system. Now one speaker works normally on one output. when i switch that same speaker and wire to...
It would appear they've blown one channel on the Amplifier and one Tweeter on your Speaker. It's more than likely that the Tweeter has blown first and overloaded the Amplifier.
The Tweeter shouldn't be a problem to replace (eBay more than likely) and you'll probably be better getting a new pair and replacing them both.
The Amplifier could be a different issue depending what Country you're in and your Technical ability?.
If you need any further assistance once you've opened the unit then just ask.
Please leave feedback
Cheers
Andy
May 08, 2011 | Fender Passport P-10 Professional...
I have a tower computer kind of older . when i plug in the microphone to the back i.e. microphone port, nothing happens to signal it reads the microphone and when i try to use the microphone for fruity...
Assuming you are running windows XP you need to
1. right click the speaker in the lower right corner and select adjust audio properties.
2. Select the audio tab
3. Pull the drop down menu under sound recording and make sure it is selected to your audio driver device. Most are either soundmax, creative(for soundblaster and audigy standalone cards), realtek, or ASUS.
4. Next repeat step one but select open volume control
5. Go to options and then properties
6. Select the circle for recording and make sure your mic input is checked.
7. Close that window and recording mixers will pop up. Select the input you need by checking the box in the lower left corner of the mixer channel. Adjust the level and then use your recording program or sound recorder under Program files>accesories>communication>sound recorder.
Mar 08, 2011 | Philips Phillips...
Mic has a small bus mixer hook up it reads on the level of the mixer but no sound comes out of the speakers?
So the mike works but the interface from the microphone amp to the subsequent unnamed electronics isn't working or set up right.
We might want to look at the mixer or beyond for the solution.
Jan 14, 2011 | Samson Stage 5H Microphone
I am trying to record with my mxl 990 micrphone onto my laptop but when i try to record no sound is heard
you can't just plug and play with these high end mics. You require a +48v phantom power source from something such as a mixer. Then plug the mic into the mixer and the mixer into the LINE IN on the PC
Jan 07, 2011 | MXL 990s Professional Microphone
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Mono
Hello sir/maam, most (almost all) mic are mono, and the microphone mixer circuit splits the signal to two channel left and right, and fed to two amplifiers, then to two speakers. IF by any chance only mono, we need to trace the path where the mic signal is fed, and where the signal dissappeared, check also your balance control.
If your mic mixer circuit is designed for one channel, contact your local tech to check out or make connection to both channel.
Oct 05, 2009 | Samson R21S Microphone
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Pls help
The MXL 990s requires 48 volts to operate. If your mixer does not have a phantom power option, you will need to purchase a microphone pre-amplifier with phantom power to interface the microphone to your mixer.
Nov 19, 2008 | MXL 990s Professional Microphone
Yamaha Mg3214fx 32 Channel Mixer With Fx System Logo
133 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
