Question about Frigidaire 27 in. Electric Gallery Pro Series Self-Cleaning Double Wall Oven
F8 / Convection portion of top oven doesn't work
In addition to my F8 Display problem (posted earlier today) which currently makes the oven inoperable, the convection portion of the top oven stopped working about 6 months ago. I was told that it probably stopped working because of using the self-cleaning feature. Given both problems, should we attempt to repair it (I have no idea how much this might cost if my husband can't fix it) or replace it? We've only been in the house 3 years, but we believe the oven is about 7 years old. We prefer to spend as little as possible, but we've already had to replace the microwave and dishwasher that were purchased at the same time (all Frigidaire) so if it's not going to last I don't want to pay for repairs and still have to replace it. Any opinions? Thanks
Posted by kmacklin2 on
Michael Masters
  • 6,784 Answers
F8 Oven door lock failure Check lock relay and door switches.
Posted on Apr 02, 2009
  • Michael Masters
    Michael Masters Apr 02, 2009
    Hi, this repair shouldn't cost much. i recommend replacing the lock relay and all switches as well.
    please rate and god bless.
Top part of oven not heating up
Thank you for your post, friend!
Based off what you have described your Electrolux double wall oven is not heating up inside the top portion. It could be a miscommunication within your oven and you can usually perform a reset to clear that out. In order to reset your oven you would need to flip the household circuit breaker off for roughly ten minutes. If you restore power and continue you having an issue with your oven I would suggest you could have a possible fault with the control panel, thermostat, element, or connectors. Typically, this is not a simple DIY job. You may need to look for assistance with replacing any electrical components and I would highly suggest having a professional technician help with that. Hope this is helpful. -Matt
Feb 23, 2015 | Electrolux 30" Built-In Double Electric...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
I have purchased a Casera 30L Microwave Oven with Grill and Convection, And have no idea how to use the times necessaryfor utilising the Microwavr Grill anf Roastin Oven.. Could you direct me as to recipe...
First of all, thank you very much for choosing FIXYA today for your technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
Cooking in a convection microwave oven certainly is a bit different than using just a standard microwave and does require some special care and technique. Here is a link to an article which describes the general priciples of cooking with convection microwaves and explains some of the special techniques required:
http://whirlpool.custhelp.com/app/answers/detail/a_id/384/~/how-does-combination-microwave-convection-cooking-work-and-how-do-i-use-it%3F
Although there is no documentation currently available online specifically for the Casera line of Microwave Convection ovens, here is a direct link to the ONLINE USER'S MANUAL for a model of convection microwave from Whirlpool with very similar features:
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208206204.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this utility pre-installed.
You can always download this for free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
As far as recipes for convection microwave ovens, there are many freely available online. Here are a number of links which will direct you to many examples of the types of resources currently available on the internet:
http://www.bellaonline.com/articles/art27624.asp
http://easyconvectionmicrowaverecipes.blogspot.com/
http://www.ifood.tv/network/convection_microwave/recipes
http://www.lifestylefood.com.au/recipes/collections/convection-oven-recipes.aspx
http://members.datafast.net.au/kristen/microwaverecipes.html
http://www.recipe-greeting-cards.com/microwave.asp
Just use your mouse to click on any of the six highlighted recipe resource links above which will then open a new browser window for you automatically and allow you to view the information at the website indicated.
Please COMMENT back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
BEFORE leaving a rating OTHER THAN 5 STARS or a negative TESTIMONIAL, please contact me and I will immediately clear up any concerns or answer any additional questions that you might have until you are completely satisfied with the service provided. The FixYa rating system is a very important component of the Marketplace, and unfortunately once you post a rating or a testimonial to a solution, it cannot be changed at all later on.
Be sure to use the small blue ADD A COMMENT button located just below the text of this solution to leave any additional comments for me regarding this particular issue and I will respond right away.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Oct 26, 2011 | Ovens
I have an bajaj oven and im trying to bake a cake and everthg i bake it the sides of the cake get baked and the middle portion remains raw..ive tried all the up flame,down flame and also both the up and...
if your oven is gas its is very difficult to make perfect baking of of the uneven heating,if your oven is elecric is with convection that one good compare to gas oven on an electric oven without convection, the advantage of oven the with convection is even heating.
Dec 24, 2010 | Ovens
F8 heat low it goes up to 494 and stops there
It generally is the IR Element that has gone bad. Look for burned wiring where the IR Element enters the oven cavity. Check for continuity through the IR Element.
1. Check that the blower motor is moving air.
o Blower motor is not moving air: Check blower motor assembly
and verify motor is stalled. Unplug oven and correct obstruction or
replace motor. (For access to motor shaft, remove top panel.)
o Blower motor is moving air: Verify high-limit thermostat is
not tripped. See the high-limit thermostat information below.
High-Limit Thermostat:
o Thermostat tripped: Reset and determine why the thermostat
tripped (See Figure 38, Item 114). Look for excess build up of
grease inside the oven or any other source for a fire.
o Thermostat is not tripped: Check main convection heater.
1. Convection heater is defective: Unplug oven and replace the
convection heater and verify the K4 SSR (Figure 37) is not
shorted across output.
2. Convection heater OK: Check the K4 SSR.
o K4 defective: Unplug oven and replace.
o K4 OK: Unplug oven and verify all wiring. Verify P1 voltage on
I/O board is 5.0VDC (+/- 0.02) -
Aug 28, 2010 | TurboChef TORNADO Electric Oven
Bake element does not work during convection cooking
Hello and welcome to Fixya.
I hadn't seen your post prior to today, so perhaps you've had a remedy presented to you already.
If you have not, reply to this post and I can recommend a few test to perform that will determine the issue with your oven.
Off the top it sounds like a possible faulty convection heating element or the K3 relay on the board is defective.
I'll watch for your reply.
Thank's,
macmarkus :)
Jun 07, 2010 | Thermador SC302T Electric Double Oven
Jenn-Air Convection Wall Oven, WW2780
I your user Manuel should be a list of error codes describing what each error code indicates!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 06, 2008 | Ovens
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Frigidaire 27 in. Electric Gallery Pro Series Self-Cleaning Double Wall Oven Logo
266 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Ekse
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
