Sound/Ground problem I recently replaced my stock radio with a jvc kd g310. I have everything wired up as it should be, but whenever i have the plug connected and antenna plugged in the radio works but dosent play sound. When the antenna isnt attached and the grounds unplugged the sound will come out but a little fuzzy, what could be wrong?
did you ever figure this out? i just replaced a broken KS-U58 cable on my JVC KD-G310 and now i can't get it to switch to EXT. everything else on my stereo (CD, radio) works fine.
The only thing i can suggest is to go to your audio shop and ask the same question to them, as they normally carry many different styles of leads and may have one there that will help you to connect your cd player, Is there a din output on the back of this unit? if so they should be able to help.
if you are talking about the time and stations "presets". pull the radio out and look for the yellow wire off the back of the radio make sure it is going to a hot wire."one with contentious power i hope this helps
Push in the select button and hold it for 3 seconds. scroll through the list using your next button for the radio on the bottom right hand corner. once it says Clock H you can turn the volume knob to set the hour. hit the next button again and it should say Clock M for minute and use the knob again.
