Question about Refrigerators
Norlake model 03080290 refreg. is too warm at 50 degree
I have Norlake model 03080290 refreg. and all of sudden this unit's temperature is running around 50 - 55 degree. I tried to dust off the coil and let it turned off for over night but didn't help. This unit is about 3 years old and I need to know whether I should call service person or get a new one. Please help.
Posted by wjlee888 on
Anonymous
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
You should call service
Posted on Apr 02, 2009
Ice machine , fan kicks on and off constantly
Hello Harold;
My name is Peter. I am a retired field service refrigeration technician.
Your fan is not designed to run constantly. Your fan will turn on when the set temperature falls 10-20 degrees below set temperature, and will run until the unit is 10-20 degrees above set temperature.
1.) Clean your condenser coil. This coil removes the unit heat.
2.) Check your condenser fan to make sure it is running.
3.) Check the door gaskets. They may be crushed or worn, allowing warm air to enter your unit.
Dec 23, 2014 | Refrigerators
I have a 1997 chevy Malibu. The car runs very good during the summer months, however when the temperature drops below 50 degrees the car wont start. When it warms up to 60 degrees it will start with n
maybe as simple as a temperature switch or sender. if its bad the computer thinks the engine is warm already so it doesnt send a richer fuel signal to start it easier. get it checked out and drive in cold weather again.
Jan 16, 2018 | Cars & Trucks
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
What should the freezer temperature shouls be????????????????
Normally, freezers are at 0 degrees. If you have ice cream, shoot for -10 degrees.
hope this is what you are looking for.
Feb 21, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
Norlake freezer 6x6 not freezing enough
Normally freezers are kept at zero. Most health departments will not allow the temp to be higher than plus 10. If you want to store ice cream, you need to be at minus 10 degrees to minus 15 degrees.
let me know if I can be of any further help.
Sep 29, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
We have norlake walk in freezer and the problem is buildup ice and the temp is 35degree right now how to bring the temperature back to zero degree
You have to defrost the coil by turnning of the unit and to make it faster leave the inside fan/s running.But if it's building up ice and the fan/s inside works ,is most probably that the unit is low in refrigerant(freon) , or the defrost system is not working.
Sep 25, 2009 | Freezers
Norlake 6x6 freezer compressor
No probably just frozen up due to door being left open turn unit off and check internal unit have a look on the evaporator (internal unit) see if it has a covering of ice if so leave of utill completly frost free and then restart I bet it will work
Sep 09, 2009 | Refrigerators
The freezer and refrigerator are not cooling down.
Make sure that the condenser coils under the refrigerator are clean. A dorty condenser will cause the unit noy to cool.
Dec 28, 2008 | Refrigerators
How do turn the temp up on a norlake walkin?
They are usually mounted on the front panel of the evaporator or mounted on the wall behind the evaporator.There is a possibility that the temp. control is at the condenser,and the sensing bulb was slipped thru the wall.Look for the bulb at the back of the evaporator and follow the cap tube.
Dec 05, 2007 | Nor-Lake Freezer Norlake Refrigeration 6'...
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
