Question about Microsoft Windows Vista Ultimate Edition
Windows sidebar stopped working
Everytime I restart my pc the windows gives an error that windows sidebar has stopped working & when I try to manually start it, then it gives the same error. I am using Windows Vista Ultimate SP-1 64bit..
Kindly provide me a solution as soon as possible..
Thank you
Posted by rohitbhatia3 on
  • 5 more comments
  • rohitbhatia3 Apr 02, 2009
    it gave an error when i typed regsvr32 atl.dll
    error number 0x8002801c
    Again I tried after restarting,it gave the same error that atl.dll was loaded but the call to DllRegisterServer failed with error code 0x8002801c..
    Please do reply
    now succeded in trying the above steps but still sidebar doesnt worked,same thing that when I try to start it it gives it has stopped working
  • rohitbhatia3 Apr 03, 2009
    when i opened through explorer as you said,then also the same thing happened windows sidebar had stopped working & windows starts searching for the solutions online & no solution are available
    do i have to register to see this post
    these are the same steps u gave before
  • rohitbhatia3 Apr 04, 2009
    well,no probs brother.. thanks for the help..
Anonymous
  • 741 Answers
Here is a solution I found when I was having problems and it worked like a gem..its a problem with two programs running a .dll file:
1. Open a command prompt by being Administrator (Right click on Command Prompt and click Run as Administrator)
2. CD to C:\Program Files\Windows Sidebar ( cd drive letter:\Program Files\Windows Sidebar )
3. Run these commands in this order:
1. regsvr32 -u sbdrop.dll
2. regsvr32 -u wlsrvc.dll
3. regsvr32 atl.dll
4. regsvr32 sbdrop.dll
5. regsvr32 wlsrvc.dll
Then start up the sidebar.
Good luck. If you have any questions let me know.
Posted on Apr 02, 2009
  • 4 more comments
  • Anonymous Apr 02, 2009
    That's a memory error..it basically means two programs were trying to use the same memory space. Make sure all of your programs are closed..also since it is a memory error you can reboot and try it again and maybe the memroy space it free up..good luck.
    Ok let me do some more research, I have Vista Ultimate also, so should have something in a few..
    Exactly what does the error say?
    Try this. First hit ctr-alt-del and choose task manager. In task manager click on Processes. See if you have a file name sidebar.exe. If not then right click on start and then explorer. Go to c:\program files\Windows Sidebar\ in this folder you will see sidebar.exe. Click on it to see if it will start up.
  • Anonymous Apr 03, 2009
    I found this in one of the Vista forums that matches your problem. Rather techie at some points but if it works I imagine it will be worth it. You may have to use the "chat' feature in Fixya if you get stuck so I or someone can walk you thru it...keep me updated and good luck.
    http://www.vistax64.com/tutorials/117192...
    really? dang..well sorry about that. Looks like I am out of bullets. Can't find any other information, and since we ran the sidebar.exe from its native folder, it looks like the program itself is corrupted. You can repost with a chat, which will bring a lot more experts to help, not to mean any of that will work either, but there will be more eyes on it. Only other recourse is to backup your data and re-install. Another way that is a long shot is to make a disc image or clone of your operating system with software such as Acronis. This will save all of your settings, but it may also brIng the problem with it, no gurantees on that one..sorry I couldn't help more good luck.
Yateesh Varma
  • 128 Answers
Click start, type SIDEBAR. In the menu, select the one for Windows Sidebar
Properties. At the top is an option to always start that you may need to
enable.
Or
Else:
You should have a spare copy of sidebar.exe in the Windows\winsxs folder. You'll need to search for Sidebar.exe to find it, as the folder names use GUIDs. Then copy it into Program Files\Windows Sidebar and see if that fixes things.
Or
If nothing works please try, running System Restore to roll back to a point before the problem started. Hopefully that'll sort it out.
Regards
Pcs365.8
Posted on Jun 04, 2010
Error on windows xp desktop page_fault_in_nonpage_area
You receive "Stop error code 0x00000050 (PAGE_FAULT_IN_NONPAGED_AREA)" or "Stop error code 0x0000008E (KERNEL_MODE_EXCEPTION_NOT_HANDLED)" when you restart a Windows XP-based computer uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png954211 MS08-061: Vulnerabilities in Windows kernel could allow elevation of privilege
  • 959252 Error message when you switch the operating system from a dual monitor setting to a single monitor setting on a Windows XP-based computer or on a Windows Server 2003-based computer that has the security update 954211 installed: "Stop 0x0000008E"
  • Note Update 959252 addresses a known issue that was introduced by update 954211.uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.pnguparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png824684 Description of the standard terminology that is used to describe Microsoft software updates
    Jan 06, 2014 | HP Computers & Internet
    Error 1005
    1. This is a generic error that describes that phone is not able to find the PC. There can be many reason for this
    2. Try restarting PC Remote Server
    3. Make sure that battery saver mode is not turned-on as phone networking is stopped when battery is low.
    4. Try restarting your PC and restart PC Remote Server
    5. Do you have any firewall or anti malware installed on your PC? These softwares might be blocking the connection with PC Remote Server. During server setup, a rule/exception is added to Windows Firewall to enable incoming connection from Phone. If your security software is not querying Windows Firewall for exceptions, then you need to manually add a new exception to allow incoming TCP and UDP connections on local port 61314. Try connecting after stopping security software.
    Please add the rules to allow incomming and outgoing connections for PC Remote Server at port 61314.
    May 03, 2013 | Computers & Internet
    I cant run cricket.exe in my windows 7 ultimate ..im using sony vaio laptop it is giving error like"problem cause stop working " please give me solution as early as possible
    try to reinstall the software but first you need to remove it completely. You can use revo uninstaller to completely remove the application and its safe to use. After uninstalling the application, restart the laptop then reinstall cricket. hope this helps
    Feb 09, 2013 | Computers & Internet
    When i switch off power and restart the pc i get error 'cmos/gpnv checksum bad' and sometime 'cmos setting wrong press f1 to set defaults or press f2 to enter cmos setup'. I replace the...
    sir have you tried clearing the jumper settings. if it still persist remove power supply of board and cmos battery for 5 mins. Then try to startup.
    Sep 14, 2011 | Asrock P4I45GV...
    Toshiba tecra m1 pc.. boot cycle keeps recycling... the windows logo appears then it auto restarts... will not finish loading windows xp same thing happens when i try to boot in safe mode.. any of the...
    If it's rebooting when trying to boot into safe mode as well, have you tried "Last Known Good Configuration"? Press F8 like you do to go into Safe Mode, and choose this instead.
    If this doesn't work, on the F8 menu, you can disable automatic restart. This will cause Windows to hang instead of automatically rebooting when it encounters an error. With any luck, it will display a STOP error for you. If you get this, comment with the error and I'll be happy to look that up for you.
    If this helps, please give a positive rating.
    Jul 05, 2011 | Toshiba Tecra M1 PC Laptops
    My gadets slide bar has gone how do i get it back
    To open Sidebar
    Open Windows Sidebar by clicking the Start button , clicking All Programs, clicking Accessories, and then clicking Windows Sidebar.
    To keep Sidebar visible at all times, you must set it so that other windows won't cover it. The Sidebar width is a fixed size.
    To keep windows from covering Sidebar
    Because of the space Sidebar requires, this option works best if you're using a large or wide-screen monitor or multiple monitors.
    1.
    Open Windows Sidebar properties by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Windows Sidebar Properties.
    2.
    Select the Sidebar is always on top of other windows check box.
    3.
    Click OK.
    Sep 18, 2009 | HP G70-250us Notebook
    Acer webcam USB probelm
    Is the webcam USB? Try rebooting the computer with no other USB devices connected. If you're still having the problem try it through a separate mains powered hub. Webcams can often overload the USB ports on laptops.
    Nov 12, 2008 | Acer Aspire 5610-4648 Notebook
    Windows dvd maker
    What OS are you using? Ultimate, Premium, Basic?
    Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
    Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
    Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
    Resolution :
    These Codec files should be located and renamed to resolve the issue.
    1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
    2. In the Event Viewer window Click on Windows Logs in the left panel
    3. Click on Application Logs under Windows Logs
    4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
    Sample Error Log :
    Problem signature
    Problem Event Name: APPCRASH
    Application Name: DVDMaker.exe
    Application Version: 6.0.6000.16386
    Application Timestamp: 4549b5b0
    Fault Module Name: nevideohd.ax
    Fault Module Version: 4.6.15.0
    Fault Module Timestamp: 459bb828
    Exception Code: c0000005
    Exception Offset: 00008b89
    OS Version: 6.0.6000.2.0.0.256.1
    Locale ID: 1062
    5. Locate Fault Module name, it should be a file with extension .ax.
    6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
    7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
    8. Locate the file and rename it.
    9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
    These steps will resolve the issue instantly without a restart.
    Sep 18, 2008 | Computers & Internet
    Windows explorer stops working and restarts when i try to access my control panel from the start menu
    try this go to c:\ right click to properties on drop down menu.
    tools on the popup fix error tick box click check now reboot computer on startup computer should scan disk for and fix any errors. this method has worked on a few computers but does not work everytime as something else is basically wrong
    Jul 16, 2008 | Computers & Internet
    Microsoft Windows Vista Ultimate Edition Logo
    306 people viewed this question
    Top Microsoft Computers & Internet Experts
    Ekse
    Lee Hodgson
    Lee Hodgson
    efs_perpends
    efs_perpends
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
