Microsoft Xbox 360 Console Logo
Anonymous Posted on Apr 02, 2009
My picture is a bunch of horizontal grey lines up
My picture is just a bunch of horizontal grey lines up the screen...however the sound works fine. I can even play cds or open the tray if I guess right in the menue screen, but can't get a normal picture.
Anonymous
Level 1:
Filmmaker:
Uploaded 5 video answers.
  • Contributor 58 Answers
  • Posted on Apr 02, 2009
Anonymous
Contributor
Level 1:
Filmmaker:
Answers
58
Questions
Helped
29924
Points
81
First, try unplugging the AV cable and hooking it back up. If that doesn't work then your graphics might be going out, which is another one of the 360s more common problems. If you still have your warranty, then you can send it in and they'll fix it free of charge, but if not you'll have to pay. There are also tutorials online that show how to fix different problems if you have the technical know-how.
Screen has gone grey and has fine horizontal lines on entire screen. Blue screen is out.
Either the screen voltage to picture tube is more than normal, or the video processor IC has damaged. There is an other possibility that there is no voltage at the video output card, plugged on to the neck of the picture tube. Anyway, your set need a through checkup, and the work is somewhat skilled one. Just check this site. Soemtimes you might get some details about this fault. The fault is called vertical retrace lines. Thin horizontal lines all across the screen with an inch apart. One among the posts published in the following site have details about this fault.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there.
1helpful
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
Horizontal grey lines running whe camcorder in play mode
Its symptoms of dirty / clogged video head. Please use Sony video head cleaning tape to clean video head.
LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
try your monitor to other computer or try other monitor to your computer to see where is the problem
2helpful
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Grey line horizontally across screen
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
T.v. sound no picture reading err 411021 on screen
It's a long shot, but you could try unplugging the set for about a minute. Philips is among my least favorite sets to repair, and with it being a 25" model it probably wouldn't be worth taking to a repair shop if the power interruption doesn't reset it.
Horizontal grey lines on TV
Sound like you have to turn down the G2 (screen)controls. They are turned up too high.
Grey screen, white lines
adjust your screen at the back of tv flyback down you see the fucos and screen adjust the sreen ok
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
