The E1 error is telling you that there is a leak in the dishwasher. After confirming that there is no leak, even directly under the dishwasher (remove the kickplate and use a flashlight.)
After ruling that out, your problem is almost certainly caused by the drain hose between your dishwasher and your drain. There MUST be a 30" rise in the drain hose between the DW and the drain. If the hose just lays there, causing a siphoning effect (law of physics) that WILL drain water out of the dishwasher into the drain as soon as a wash or rinse cycle begins (after 1 - 2 minutes after they begin. Then the E1 error will be displayed.
The BEST way to fix this problem is to install an AirGap valve (almost free @ any hardware store) in your counter/sink and then running the short pipe to your disposal or sing drain inlet. If that is not possible or for a quick and dirty repair until you can install the AirGap, tie the drain hose to the bottom of the counter top so the rise is created.
Good Luck!
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
