The RX600 does not print anymore. The screen on the printer message is ''Setup menu-service required. parts inside your printer need to be replaced. See your user guide for support information.''
This message indicates that your waste ink pads are full and require replacing. Replacement is costly, messy and requires the printer to be taken completely apart. Most often the counter has "jumped" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
