I think the outer glass is just glass (where I HAVE found them... they WERE cheaper than the INNER GLASS)...
Your model number resolved to the UK... being here in the USA
I am pretty confident the differences ARE NOT insignificant...
All I'm seeing from here is inner door glass starting at £60...
I looked up OUR version of a Miele Double oven...
they are really quite NICE.
The inside glass is the critical one... Failing to find an "outer glass" Your LOCAL Parts/Spares retailers might be willing to suggest LOCAL GLASS shops.
(I'm just suggesting... never tried).
But also confident if you have a screw driver... you can do this!
and can construct a good search line Like:
Miele+H348B2+DOOR+GLASS
You should be able to locate a good part at a reasonable price... &
You should be well on your way...
The first URL I put below depicts a typical Whirlpool oven glass replacement VIDEO (not difficult... Certainly not as clean as they show).
Hi, Please can you help to find a part number for outer door glass or is any other outer door glass suitable for AEG MCC3880EM I can fit in? Many thanks
Please can you help to find a part number for outer door glass , how much it would cost or is any other outer door glass suitable for AEG MCC3880EM I can fit in? Many thanks
Hi Try not to open door with handle as this may cause to glass to smash. When you open the door you will see two pin sticking forward near the top of the door just further back on the top of the door is two small barbs push down on these barbs located in line but further back from the pins.This will release the top of the outer door.The bottom of the glass is hooked into the hinge. with the top released lift door glass away.You should find screw in inner door refit screw with some loctite.
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it. 1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door. 2 Remove the outer screws , starting from lower side of the panel. 3Removethe
inner screws. Keep all set of screws ordered, and take note of theorder
you remove them. You will follow reverse order in reassembly. 4 the frame will be free now, 5 Remove the external glass panel and leave it in a safe place. 6 Replace the inner glass. 7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
"removed the door from the
oven by releasing clips attached to the door hinge -- very nicely
engineered. Removed about 6 philips head screws to allow the door
assembly to be taken apart for access to the glass. Lifted out the
broken glass, cleaned the inside of the door, installed the new glass,
reassembled the door (a two minute project), and reattached the door to
the oven. Cleaning the inside of the door"
"I removed the oven door by
lifting it off with the hinges. Disassembled the door parts one at time
making sure I remember where I removed the screws until I am able to
get to the broken glass. The most difficult part is making sure that
the insulation strip & the gasket stayed in place after I replaced
the broken glass & doing the reverse process of installing the
parts together. Relatively easy process as long as you remember where
the parts go. When in doubt, I had to refer to the pictorial of the
disassembled door shown on your website."
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Cooker
