Question about Acer Aspire One AOA110-1113 Netbook
Restore cant restore to factiry settings
Posted by blake328 on
  • Anonymous May 11, 2010
    Which operating system are you using (Windows XP/Vista, Linpus, etc.)? Are you using the Acer eRecovery Management?
    Please post as many details as possible, including the steps you took to try to restore to factory settings.
    Thanks for using the FixYa Forums!
Gaurav Kumar
  • Acer Expert
  • 560 Answers
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Posted on Sep 20, 2012
Anonymous
  • 33 Answers
I actually have one of these, I just went and got Fedora 10 (Fedora version of Red Hat Linux vs. the pre-installed Linpus version of Red Hat Linux) and installed it instead. Anyways, there should be a way to take the cd, load it onto another computer, and have it put itself on an empty 2GB (or bigger) USB thumb drive if you can't get a cd loaded onto it. I did this several times before I went to Fedora 10, and the wireless works in Fedora 10.
Posted on Apr 01, 2009
Philips 55p8341a to much red
Go to the factiry settings using the remote n look for rgb intensity balance or check the stk amp n replace it it controls the red chroma n lighting
Nov 02, 2015 | Philips Televison & Video
Format code nokia 1209
my imei no.356927036305492. forget my restore factiry password
May 20, 2013 | Nokia 1209 Cell Phone
I cant log onto the web site or ip 192 thing to change my password,i cant remember my password and want to change it, but the site is always down or an empty page.... why cant they just make these things...
Here is the procedure to reset the system to factory default:
To use the restore settings button:
1. Locate the restore factory settings button on the rear panel of the router.
2. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings
button for about 5 seconds, until the Power light begins to blink.
3. Release the restore factory settings button, and wait for the router to restart, and for the Power
light to stop blinking and become solid green.
The factory default settings will be restored so that you can access the router from your Web
browser using the factory defaults.
Here is the link to download the manual.
Best of luck, Jim
May 01, 2011 | NetGear WNR2000 Wireless Router
I have tried to reset my netgear wireless router, to make it return to its factiry settings, but it just wont work and i have completely forgotten my login information. is there any other way to reset it...
Have you tried the "hidden" reset button on the back of the router?
Try a paperclip, a fine ball point pen works too, hold in for 30 seconds.
If you have not changed the default user name and pass try these:
user :admin
Pass: password
Nov 02, 2010 | NetGear WGR614 Wireless Router
Dell latitude c610 . how do i reset it back to factory settings when in the bios setting.
when in BIOS you will see at the bottom of the screen or somewhere on the screen depending on your BIOS chip (AWARD or AMI) THE MESSAGE "RESET DEFAULTS OR FACTIRY DEFAULTS.This resets the original setting when you aquired the system.
Jan 01, 2010 | Dell Latitude C610 Notebook
Factiry image d is red how can i fix it
monitor problem . check ur connected cable or power cable.
Jul 18, 2009 | Computers & Internet
PS3 RESTORE PLEASE HELP
restore to default settings. Bear in mind, all your custom saved settings will be lost.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Hi i need a security code 4 ma nokia 6230
For any Nokia mobiles the default security code will be 12345. If the code is not working then try 4 zeros or 5 zeros. The security code can be changed. If any of them is not working then it might have been changed. Try 12345. Hopefully it should work. Thank you........
Sep 13, 2008 | Nokia 6230
Parental code
Try to reset the PS3 by holding down the power button for at least 5 seconds. Otherwise, you can try this:
1. From the XMB home menu, go to icn_settings.gif (Settings) > icn_syssettings.gif (System Settings) > [Restore Default Settings].
2. Once you select [Restore Default Settings], you willsee a list of settings that will be restored. Scroll through them andpress the icn_btnx_color.gif button to restore the settings.
3.
  1. After the operation is complete, youwill see the initial setup screen that appeared the first time youturned on the PLAYSTATION 3.
    You will need to go through the initial setup process before you can use the PLAYSTATION 3 again.
IMPORTANT
TheRestore Default Settings feature will erase any previously savedsettings and restore all of the following settings to the default:
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Date and Time Settings
  • Accessory Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
  • Internet Browser Settings
Also,do not confuse [Restore Default Settings] with the [Restore PS3 System]option (the next option down on the menu). The [Restore PS3 System]will not only restore the default settings, but it will also delete all hard disk content. (You will lose all saved content from your PS3 system's hard drive if you use [Restore PS3 System].)
Jul 24, 2008 | Sony Playstation 3 (PS3) Console
Acer Aspire One AOA110-1113 Netbook Logo
285 people viewed this question
Ekse
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
