2004 Land Rover Discovery Logo
Posted on Apr 01, 2009
Land rover Discovery 2004, rear right hand side down 2 inches
The rear right hand side of the discovery is about 2 inches lowere than the rear left or the front.
debcalcampbe
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jun 15, 2009
debcalcampbe
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
14138
Points
30
If you have the coil spring suspension, then your spring for that corner has really sagged[doubtful] I suspect you actually have the rear air suspension ,and the air spring for the Right/Rear has lost air, allowing the rear end to lower down greatly. Usually, you need a new air spring when one develops a leak. You may or may not be able to see the leak with a spray solution of soapy water after the spring is removed for inspection. Sometimes you have to apply about 20psi of air pressure into the spring to inflate it a bit, then put the spring under water in a big enough tank/tub of water to catch the leak that way.
Land Rover Discovery Series II has the lights on the left front, rear left on at all times. Is it a fuse?
Unlikely to be a fuse blown. Doesn't your Discovery have Daytime Running Lights? If so the right side might be a blown fuse. If the rear lights are on, that mean you have the nighttime lights on.
My mother worked at Land Rover in Solihull for 12 years. :>)
Fuses and relay Land Rover Discovery 2 - Fuse box diagram
fusesdiagram.com https://fusesdiagram.com > land-rover > fuses-and-rela...
Passenger compartment fuse box is located below an to the side of the steering column. Remove cover using a coin or small screwdriver and turning 90 degrees.
They seem to suffer with funky electrics
https://www.google.com/search?q=land+rover+discovery+2+left+front+left+rear+lights+on+all+the+time
Common problems with disco 2 year 2000. thanks v8
Hi welcome main problems are the abs valves causing the 3 dash lights (search 3 amigos online) a really badly sited compressor can cause air suspension models to fail giving the bags a slow leak the V8 is a solid engine but can have radiator expansion tank and cap failures
the other issue is electrics windows and door looms are problematic
1998 land rover wont start .It is not getting and fire to the fuel pump.
I had the same problem with my 98 discovery ..on mine the stering is on the left side ....on the right side under the glove box on the harnes wire there is a smal blue thing 1/2 x 11/2 inch box ( HJ1 splicer) power from the fuse is going in there and jumps with the wire from coil,fuel pump relay and the computer.In my car that jumper was not making contact ..after i shorted all 4 wires the car just started up.
5helpful
2answers
2001 land rover discovery II locate fuel filter and fuel pump
for Land Rover Discovery 1999-2004 no more external Fuel Filter serviceable anymore...it's a built-in part with the fuel pump. so if you want to change the filter then change the whole fuel PUMP.
Land Rover disco 2, rear suspension lower
SPRAY REAR AIR BAGS WITH SOAPY WATER AND LOCK FOR BUBBLES. dOES NEW PUMP KICK ON?
3helpful
If you're standing looking at the rear of the vehicle, it's on the chassis rail on the right hand side rear wheel arch.
1helpful
Is it possible to fit land rover discovery 2 wheel hubs to a land rover discovery 1?
is their any difference?? i would really need to get my hands on and around this to see whats what ,but i should think it could be done
Where is the VIN
Stamped on the right hand side chassis member forward of the front spring mounting turret
24helpful
7answers
WHERE IS THE FUEL FILTER LOCATED ON LAND ROVER DISCOVERY 2000
LAND ROVER DISCOVERY II DONT HAVE FUEL FILTER, ONLY HAVE PRE FILTER IN THE FUEL PUMP
Top Land Rover Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Land Rover Expert? Answer questions, earn points and help others
