My xbox360 will not read disk can u help
If your XBOX 360 is under warranty just send it back to Microsoft and let them fix it. If not, you need to find instructions on YouTube to disassemble your XBOX and then you will need a cotton swab that has two ends on it like the ones you clean your ears with. Use lens cleaner like you would clean eye glasses with or something that will not streak. Be very careful not to damage the laser. Gently take the swab with the cleaner on it and rub it around the laser lens in a clockwise motion about 3 times. Do the same thing counter clockwise. Now turn the swab around to the dry end and perform the same tasks in reverse order. So...you will use the dry end counter clockwise 3 times and then clockwise 3 times. Now put your XBOX back together and see if it has fixed the problem. There are a couple of other options to try as well but you didn't mention anything about it grinding so I did not post those fixes. Let me know if you need them.
This is a problem occurring in all the xbox 360 consoles.......
this is mainly because of the poor quality of the disc.....as a result it leads
to the damage of ur xbox 360 lens..............use good original
discs........the heating effect is due to the long usage of pirated discs ...
check your lens if its working good then better
download this Repair Guide for further information .........
CLICK HERE to download
Though i fixed the Disc Read Error myself within anhour but please test the
below method at your OWN Risk. Please alsonote that microsoft is no longer
providing Extended warranty for E74Error.
Check out this DIY Video
Guide,that explains step by step instructions to fix Disc Read Error
yourselfwithin an hour. It also provides the money back guarantee in case youare
not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys...................................
SOURCE: everytime i put in a new game my xbox360 disk wont
Get in touch with Microsoft for a replacement or repair.
I believe it is still in guarantee.
You could also try to remove the front cover case of the xbox to see if something is blocking the closure mechanism.
Hope it helped.
SOURCE: xbox360 can't read disk
there are series of problem in xbox360 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the xbox360 repair guide that will help you a lot Click Here
