Question about Home Fencing
Craftsman 3 ton floor jack will not stay up
My craftsman 3 ton floor jack does not stay up, it gradually goes down with a load on it. Is there anything I can do to stop it?
Posted by corey_farmer on
  • oneton Apr 30, 2009
    I overextended my 2 ton floor jack and now it won't go up. It just seems to bounce up and down when I pump it.
Anonymous
  • 67 Answers
You need to bleed the air from the cylinder. there should be an air bleed or else you bleed it at the relief needle. also, if it still leaks down after you bleeed out the air, the seat for the relief valve or the seals at the relief valve cartridge are worn
Posted on Jun 25, 2009
How to overhaul/ repair a hydraulic floor jack?
Sounds like a bad seal on that plunger that pumps up and down. That plunger should unscrew and then it's pilled out , there should be an O ring. That is where it probably is leaking. You probably need to top off oil. You can jack oil in an auto store or Lowes, etc.
Jun 08, 2014 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
Garage door opener fluctuating up and down travel?
reprogram the system with the control fob as it indicates that the program is corrupted possibly from recent power fluctuations
Jul 21, 2017 | Sears Craftsman LiftMaster Chamberlain...
What is a jack lift?
"A jack lift is a mechanical device used as a lifting device to lift heavy loads or apply great forces. Jacks employ a screw thread or hydraulic cylinder to apply very high linear forces.
A mechanical jack is a device which lifts heavy equipment. The most common form is a car jack, floor jack or garage jack which lifts vehicles so that maintenance can be performed.
More powerful jacks use hydraulic power to provide more lift over greater distances. Mechanical jacks are usually rated for a maximum lifting capacity (for example, 1.5 tons or 3 tons)." (Wikipedia)
Oct 07, 2013 | Hoisting
Jack will not stay up under a load
the jack could be leaking oil out of the ram. the seals will need replacing if the ram is leaking.
Jan 29, 2011 | OTC Stinger 3 Ton Jack Pack
Floor jack won't stay
If you are having a problem with the jack slipping...if its Craftsman , they may take it back and provide a replacement. Even if you could fix it, it never works that same. It is not worth your life. I know, I lost my husband when a jack slipped 3 years ago this month.
Jun 01, 2009 | Hand Tools
Floor jack will not raise even without load
sounds like either pump piston seals or check valve on pump.
Apr 02, 2009 | Plumbing
What Jack and stand to get for my '04 Ram 1500 Short Bed V6?
THE SAFEST CHOICE IS THE 3 TON.. YOU COULD GO WITH THE 2 OR 2.5 TON, BUT WITH THE SIZE OF YOUR TRUCK YOU NEED THE 3 TON..REMEBER TO ALWAYS USE THE JACK STANDS..GOOD LUCK KEITH...
Mar 14, 2009 | 2004 Dodge Ram 1500
Hi i have a 3 ton sears floor jack i can not
I think I have the same jack. Th serial number was on a little sticker that is long gone,but the model number you need might needs is: 875.501390.
Hope this helps.
Gary
Mar 01, 2009 | Plumbing
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
1-800-221-9705
John
Sep 27, 2008 | Plumbing
Home Fencing Logo
7,988 people viewed this question
Top Home Fencing Experts
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
