Question about Xerox Office Equipment & Supplies
Reseting xerox drum chip xerox 5834/vivace 340
I would like to reset my xerox 5834 /vivace 340 drum chip how can this be done ?
or where can i get a resetting machine .
Posted by makitech on
sanimd85
    New Friend:
Canon pixma ip3680 absorber is full
Posted on Apr 07, 2013
Tareq Bin Mostaq Mostaq
    President:
  • Xerox Master
  • 1,449 Answers
You should change drum chip then fix your problem
Posted on Mar 24, 2013
1 Related Answer
Anonymous
SOURCE: toner drum chip reset for xerox docucolor 250
I am also having the same problem I am located in Mumbai
Please Contact me on 09867289866
I know you, but i dont have your number
regards
Pragnesh
Posted on Sep 22, 2008
How to reset xerox m118 drum
Hi, I have a solution to your problem click on the link below which will direct you to a step-by-step guide to fix your problem!
Xerox Workcentre 123 128 Reset Drum Life Free
Aug 26, 2014 | Xerox WorkCentre M118 Black and White...
Xerox workcentre 6505 reset drum
You will need to replace the chip on the drum unit with one like this that is available for purchase.
2pcs Drum Reset Chip Imaging Drum Unit for use in Xerox Phaser 6500...
Mar 20, 2014 | Xerox Office Equipment & Supplies
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
How do i reset my drum for xerox workcentre 7345
You can't reset the drums counter on the machine. The drum has what they call a CRUM on it. It's the micro chip on the drum frame. You can buy new CRUM's or use one that still has some life on it. Press the two plastic retainers to remove the CRUM.
Nov 30, 2012 | Xerox WorkCentre 7228 7235 7245 7328 7335...
I have a xerox xc1040 copier. The paper jam light is stuck on (it is the red light in the center of the display). I have gone through the entire sequence of recommended steps in the Xerox PDF files for...
Sounds more like the drum life chip has expired. Either replace the drum unit or the chip .
I can't remember if the xc1040 has a chip, or if its the one with the gears on front that has to drop a flag in order to reset the drum count.
Either way, I believe replacing the drum unit is the solution to your problem.
Dec 13, 2010 | Office Equipment & Supplies
Respected sir i am having docu color 3535. the working condition is excellent. recently I faced a problem "change the drum unit". are there any possibilities to reset the drum counter. with...
Although you can not reset the counter by any buttons. You can replace the chip on the cartridge at a far less price.
Google a business called "the parts drop".
I have done business with them for years. Give them a call, ask for Britt, they will have what you need. They are simply the best people to deal with for Xerox parts. Courteous and honest.
Cant ask for more.
The chip is easy to replace.
Nov 12, 2010 | Xerox DocuColor 3535 Copier
Need to reset replace drum message on Xerox Workcentre Pro 416
You can replace the chip on the drum unit. Or the drum unir itself.
Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
Aug 19, 2010 | Xerox WorkCentre Pro 416DC Copier
Xerox DC50 error 9-378 Drum cartridge count expired. How do i reset this error.
You can order a crum chip or replace the cartridge.
Google a business called The Parts Drop.
Call and ask for Britt. I am sure he will have the crum chip to replace and reset that code fairly cheeply.
Aug 09, 2010 | Xerox Office Equipment & Supplies
Toner drum chip reset for xerox docucolor 250
dc250 crum reset solution done yes B Patel mumbai 09029222006
Jul 21, 2008 | Office Equipment & Supplies
Xerox Docuprint C1618 Colour Laser
Are you certain you have typed the right model number? I can't find a Xerox 1618 anywhere. I would love to help.
Mar 24, 2008 | Office Equipment & Supplies
562 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
